Old 04-07-2016, 08:03 AM   #1
Top Won't Open
2002 Boxster....
Opened yesterday, won't open today. When I unlatch the top, the two windows drop, but when I push the button to open, nothing happens. One observation.... When the parking brake is engaged, the dash light doesn't come on (although it lights with the others upon startup). Last week I returned home after being away for a few months and my battery was dead for an extended period. There have been some "buggy" things happening such as the oil light being on when I wasn't low, the stereo not powering up, etc.... I don't know if the parking brake may be another 'buggy" programming issue, perhaps a sensor somewhere, or whether or not this is the cause of the top not opening. It's been working fine up until today.
samg1965 is offline   Reply With Quote
Old 04-07-2016, 08:12 AM   #2
Fintro11's Avatar
Ignition switch / your parking brake micro switch
Both problems are most likely un related, both are simple to do
Ignition switch you can use the vw/Audi part ( Google )
Micro switch is simple too there are some diy on here
Old 04-07-2016, 09:38 AM   #3
Update.... After raising and lowing the brake lever a few times, the console light came back on... The convertible top subsequently started to work again!!!
Fintro11.... The ignition switch was replaced last year as it wasn't retracting back into potition after starting. Likely the parking micro switch. Thanks!!!
Old 04-07-2016, 10:01 AM   #4
78F350's Avatar
The top wouldn't close on one of mine. I was able to pull out the ash tray and trim surrounding it, then poke the switch at the base of the brake lever to get it working. Maybe next week, I'll pull out the whole center console and replace it. Having the top stuck open at the wrong time can be bad.
Old 04-07-2016, 10:21 AM   #5
Just bypass the switch! Easy to do and you don't have to worry about it. The dash indicator will still work when you use your parking break but your top control module won't be looking at the micro-switch.
Old 04-07-2016, 11:48 AM   #6
Luckyed
Luckyed's Avatar
I had the same problem.
Installed the Comfort Top module.
Problem solved AND a much better set-up.
2001 Base 2.7 - Arctic Silver - 5 speed - Comfort Top -
3-4 Stalk OBC Upgrade - Double DIN Head Unit
Luckyed is offline   Reply With Quote
Old 04-08-2016, 02:43 AM   #7
flouese's Avatar
How do you do this?
99 Boxster base
1966 912 3 gauge
flouese is offline   Reply With Quote
Old 04-10-2016, 06:01 AM   #8
Thanks for the replies guys... Good information.
Old 04-11-2016, 10:59 AM   #9
mikesz's Avatar
I had similar problem. Replaced the micro switch in the console and then did the relay hack by bending the 2 tabs and soldering a jumper in the relay.
99 Porsche Boxster
