Old 03-30-2016, 09:25 AM   #1
texomawaves's Avatar
dissecting and analyzing an oil filter
Any easy or typical way to do this? I don't suspect any issues, but wanted to know how to detect any normal or abnormal conditions. Do you just rip it apart and run a magnet through it? Thanks!
Chris Dennis, Plano, Texas
'07 Boxster, arctic silver, Tiptronic, 106k miles, no mods
‘13 Boxster S, black on black, PDK, 27k miles, garage queen
‘66 Mooney M20E, hangar queen
texomawaves is offline   Reply With Quote
Old 03-30-2016, 09:40 AM   #2
DrCactus's Avatar
Running a magnet is probably the easiest way.... dry it out after and use a magnifier and check for any issues that way. I'll be doing this in a couple weeks time myself.
DrCactus
Old 03-30-2016, 10:15 AM   #3
2003 S, Arctic Silver, M6
paulofto's Avatar
If it is the OEM style filter it is very easy. Use a razor knife to cut the ends off and unroll the filter paper. Anything other than oil should not be there. You may see some specks and if so run a magnet over them to see if ferrous or non ferrous.
A small amount of non magnetic material is normal, after all that is why there is a filter. Anything ferrous could be an issue so further analysis would be needed.
The spin on sealed unit filters are a bit more problematic but someone on here posted a link to a filter cutter so they are around.
Good luck with your filter check. Remember, change your oil every 3 - 5K miles.
