Old 03-23-2016, 02:44 PM   #1
Control Arm Question
I'm a knucklehead --- I'm trying to replace the front and rear control arms to eliminate some clunking / rattling. So I bought the rear TRW "Control Arm Links" but just realized they may be just "links" and not actual "control arms". Is this correct? If so, what should I have purchased?
What I bought:
1998 Porsche Boxster Base Convertible - Suspension, Shocks & Springs - Page 3
What's is this?
Pelican Parts - European Automotive Parts and Accessories - Porsche • BMW • Mercedes • Volkswagen • Audi • Saab • Volvo • MINI
Thank you!!!
SvenskaPoika is offline   Reply With Quote
Old 03-23-2016, 03:27 PM   #2
Racer Boy
Racer Boy's Avatar
I'd try replacing the "links" you got, as they are most likely the source of the noise, and are a lot easier to replace anyway. These are shown in your first link as the first two items. If those don't fix the problem, then I'd replace the actual control arms, often referred to as "coffin" arms (they are shaped like old-fashioned coffins). They are the bottom two items shown in your first link. Replacing these is a lot more involved than the trailing links.
The drop links that connect the upright to the sway bar can also rattle. Those are easy to replace as well.
Old 03-23-2016, 05:33 PM   #3
CrisZenithBlue's Avatar
i initially replaced the drop links that connect to the sway bar and didnt fix my clunking but they are known to be the culprit.
when i replaced the trailing arms, the ones you have, is when the clunking went away so you are on the right track.
CrisZenithBlue is offline   Reply With Quote
Old 03-23-2016, 05:59 PM   #4
oldskool73's Avatar
Same here, replacing the first items in your link, the "Control Arm Link (Track Arm, Rear Left or Right)", fixed my loud klunks over bumps in the rear.
The second link is the same part, but for the front end, they are different size in the Boxster.
If you are doing the front and rear you'd want 2 of the first link item (for the rear), and 2 of the second (for the front).
oldskool73 is offline   Reply With Quote
