Old 03-20-2016, 10:02 AM   #1
codes p0410/p1411
Are these secondary p0410 and p1411 codes going to hurt engine if i drive
gas mileage and driving feels fine
Thx Bro
Chris Balady is offline   Reply With Quote
Old 03-20-2016, 01:33 PM   #2
Generally, the car should be ok to drive and shouldn't cause any additional damage.
Old 03-20-2016, 01:45 PM   #3
Thanks for the info..much appreciated
I plan on check valve change soon but just wanted to be safe
Ive heard it can damage your cats and maybe good case its just a vac leak
Thx Bro
Old 03-20-2016, 09:00 PM   #4
While a continually rich running engine can damage the cat's (and the Boxster engine does run rich at startup), damage to the cat's in this scenario is not likely since the engine does not operate very long in this condition (usually just a min or two).
Old 03-21-2016, 04:24 AM   #5
Xpit77's Avatar
Changing out that valve isn`t the easiest dyi. There`s lots of threads on this.Do some research before you start.Clear the CEL and see if it returns.I had the valve changed on mine but the light comes on maybe twice a year.It may be plastic hoses. Best to do a smoke test before you start removing parts. Ie. fuel rail , intake .
99 Boxster sold
88 944S sold
Xpit Formula Four sold
95 Integra Solo I sold
71 Opel GT sold
