Old 03-15-2016, 03:30 PM   #1
Oil filter housing torque
The torque to crankcase is 19 ft lbs. I've bought 2 different 74mm tools that neither worked. One wouldn't grip and the other just takes off. Can I just hand tighten the heck out of it with my hand? I've always done with all my other cars with no issue. I turned until I couldn't turn anymore. Thoughts?
DWBOX2000 is online now   Reply With Quote
Old 03-15-2016, 03:35 PM   #2
Tightening by hand has always worked just fine for me. No leaks or other concerns.
Old 03-15-2016, 03:41 PM   #3
Yeah you can hand tighten it. I bought my tool from amazon and it works just fine though. Should be 18 ft lb not 19. 19 is the magnetic drain plug.
Old 03-15-2016, 04:27 PM   #4
Bentley 19 +_ 1. No mention of magnet. Bentley wrong?
Old 03-15-2016, 04:31 PM   #5
I had always read 18 for the housing and 37 for stock plug. Not that 1 ft lb makes a difference. If Bentley says 19 they probably are right. I don't have a Bentley so I couldn't tell you.
Old 03-15-2016, 04:37 PM   #6
Do you guys have your oil analyzed? I was as a ims warning. I guess that doesn't provide any warning typically. I am contemplating putting the $30 in my ims retrofit fund instead. Thoughts?
Old 03-15-2016, 04:46 PM   #7
jb92563's Avatar
Take the first $30 and do the DIY magnetic oil filter and drain plug.
That ought to tell you when something bad is starting happen and will extend the life of your engine bearings by removing the fine ferrous particles that are passing through the filter.
Old 03-15-2016, 04:50 PM   #8
I did buy and install an LN magnetic plug. See what happens. Filter looked really good. I tore that thing apart looking for something metallic. Nothing. Anyhow thanks.
