Old 03-08-2016, 03:02 PM   #1
So I changed my oil.
I replaced filter and added just below 9.25 quarts. I noticed the oil indicator says the oil is one bar below the full line, so above middle. Is that okay or should I pull some out. I went a little low so I wouldn't overfill so I am surprised it registers a bit high. I haven't check the dpi stock yet. I did run the car to 180. Thoughts?
Old 03-08-2016, 03:03 PM   #2
Dip stick, not whatever I wrote above.
Old 03-08-2016, 03:17 PM   #3
That is right where you want it. But check the dipstick because sometimes the digital isn't accurate. 9.25 is more than I can usually get in there.
Old 03-08-2016, 03:29 PM   #4
"50 Years of 550 Spyder"
10/10ths's Avatar
And....
.....despite what the owner's manual says, check it after she has sat for three nights without running to get an accurate reading.
On these engines, a little too little, is WAY better than a little too much.
The flat engine sump design can handle a lower oil level without drama better than other designs.
10/10ths is online now   Reply With Quote
Old 03-08-2016, 03:49 PM   #5
I read the 9.25 quarts in the Bentley manual for a filter change. Maybe I read something wrong.
Old 03-08-2016, 03:51 PM   #6
9.25 is probably right if you can get all the oil out and let it drain for at least an hour. I've never been able to get that much out. I usually end up filling between 8.5 and 9
Old 03-08-2016, 04:11 PM   #7
It drained for over 20 minutes, tilted, level. Probably an hour.
Old 03-08-2016, 04:14 PM   #8
Oh, I probably got closer to 9. I am assuming the lines on the side of the mobile one 5 quart each represent a quart. Lines on left. 2 jugs, left with just one jug at just above the bottom line.
Old 03-08-2016, 04:16 PM   #9
Sorry lines on right. I'm losing my mind. I wish they would put the #'s on the side versus just a line.
Old 03-08-2016, 06:35 PM   #10
78F350's Avatar
Lol @ rapid fire posts. Take a deep breath...
I recently did oil changes on three of mine. The level looked great on the cluster and dipstick right after I filled it. The next day it was 2 marks higher on the cluster and noticeably a little higher on the dipstick. I'm not sure if it was from the oil settling in, or from being out of level.
It's easy to drain a little oil out if it is high by just pulling the filter housing and dumping it.
Old 03-08-2016, 08:02 PM   #11
stelan's Avatar
I do 9. No more, 9.25 would be ok but do not add more
stelan is offline   Reply With Quote
