Old 01-21-2016, 08:53 PM   #1
thom4782's Avatar
Buy the car that's advertised in Orlando
Old 01-21-2016, 10:00 PM   #2
njbray's Avatar
Seems like a lot of problems for only 57ooo miles.
Either get a good ppi or look for another car.
njbray is offline   Reply With Quote
Old 01-21-2016, 10:04 PM   #3
Motorist & Coffee Drinker
78F350's Avatar
+1 on the PPI
Overall there is nothing listed that is abnormal for a 2000 Boxster starting to fall behind on regular maintenance.
11/17/2010 NOTE: ENGINE LEAKING OIL FROM VALVE COVERS,SPARK PLUG TUBE SEALS EST
12/11/2015 NOTE: OIL LEAK HAS WORSENED. NEED TO REPLACE VALVE COVER GASKETS AND TUBE SEALS. EST. 998.00 .
The spark plug tube seals are pretty common and a regular maintenance issue. Something to take care of soon, but not a deal killer at all. Valve cover gaskets are a lot less common failure. I expect the dealer added that on and it may not be leaking (Check with PPI).
ALSO POSSIBLE REAR MAIN SEAL LEAKING EST 678.00.
This needs to be verified (PPI) and fixed if it is leaking. It involves removing the transmission and is a great opportunity to get the IMS bearing done if the RMS needs to be replaced.
ENGINE LIGHT IS COMING ON DUE TO BAD O2 SENSORS EST 519..00
$757 (PARTS & LABOR).
No big deal, could be replaced cheaper.
WATER PUMP IS SEEPING. NEED TO REPLACE WATER PUMP AND
THERMOSTAT. EST. $601 (PARTS & LABOR).
A regular maintenance item, but should have been replaced before it got to leaking. A pump failure would be a big problem.
AXLE BOOTS BLOWN. NEED TO REPLACE. EST. $466 (PARTS & LABOR).
Not uncommon, needs to be fixed. CV shaft bearing could be compromised if it went too long.
12/11/2015 NOTE: RIGHT SIDE TIRES ARE VERY WORN. EST. $404 (PARTS & LABOR).
Not uncommon, but may indicate worn out suspension parts $$$ (PPI).
06/08/2016 Perform Lube, Oil & Filter Exchange on 6/8/2016 or 64700 Miles.
'The 986 Forum' generally recommends an oil change every 6 months or 5,000 miles, whichever comes first. Do not ask "What is the best oil." ...search.
Old 01-22-2016, 03:57 AM   #4
husker boxster's Avatar
As F350 says, on their own none of the items are red, red flags. However, think you've nailed the MO of the owner - lives oblivious to anything going on and just drives the car. The last part is the problem. Sounds like maintenance was totally ignored. That's not a good thing. If an oil leak developed in 2010, how would it be any better in 2015? Why would it take 5 yrs to (not) address it? If he would ignore that, what else did he ignore? How bout oil change intervals? My guess is he did the "recommended 12-15K mi range", which is way too long.
If you buy this car, you better buy it for a real song because you're going to have massive ($3K+) repair bills. There will be more issues that surface than is on the list. Having another PPI should bring them to light but won't catch everything. You will spend the first yr of ownership always fixing something. That may sour your Porsche experience.
Maintenance is pay me now or pay me later. The owner skipped the first part and wants to pass it to you for the latter.
1989 928 S4 5 spd - black
Old 01-22-2016, 04:47 AM   #5
kk2002s's Avatar
So I'm guessing oil leaks and water pump repairs were never done?
Do you like projects and are you a DIY car guy?
As mentioned, there are a lot of issues a bit early for this car's mileage.
Definitely a PPI and an offer that allows you to throw some cash at it
OR
just drive it the way it is - UNTIL!!
We all like to just drive our cars but if you looked on this forum, these cars require trying to stay a step ahead of known vulnerable components
Good luck
Seal Grey
Old 01-22-2016, 05:46 AM   #6
[QUOTE=kk2002s;480990
Good luck[/QUOTE]
Preventative maintenance is the key with Porsches and maybe most German cars. It's an idea you have your get used to.
Old 01-22-2016, 07:58 AM   #7
orlando car
buy the orlando car IMO
nicecar is offline   Reply With Quote
Old 01-22-2016, 09:25 AM   #8
78F350's Avatar
vheilman, In case you are slow to figure it out, like me, the car in Orlando is this one in the classified section of the forum:
http://986forum.com/forums/boxsters-sale-wanted/60105-fs-2000-porsche-boxster-s-tastefully-modified-orlando-fl.html
