Old 01-10-2016, 07:06 PM   #1
odometer, clock don't go off
I recently purchased a 2004 Boxster S. My odometer and clock stay on all the time. I'm trying to figure out if this is normal. I read some other threads indicating they go off after 5 minutes or so but that is not the case with mine.
Any thoughts on whether this is normal and if not, where the problem might be?
Thanks for the help.
Dave
dh_berman is offline   Reply With Quote
Old 01-10-2016, 09:39 PM   #2
steved0x's Avatar
Do your interior lights stay on too, or does it act like a key is still in? If so it might the electrical portion of the ignition switch, which can be fairly common. Search for ignition switch threads to find more details.
Old 01-11-2016, 04:04 AM   #3
The interior lights don't stay on, just the odometer, clock and speedometer I think. Does that point to the electrical portion of the ignition switch?
Old 01-11-2016, 04:38 AM   #4
Lock your doors.
Old 01-11-2016, 06:42 AM   #5
This happens when I lock the doors too.
Old 01-11-2016, 06:58 AM   #6
steved0x's Avatar
My bad on the interior lights, I was thinking of something else... (door lock microswitch).
I'm not sure why they would stay on.
Old 01-11-2016, 07:36 AM   #7
Can anyone tell me if it is normal for these to stay lit? I'm not even sure if I have a problem. Again, it is the odometer, clock and speedometer.
Thanks,
Dave
Old 01-11-2016, 09:17 AM   #8
No it isn't normal. Mine may sometimes stay on if the doors are unlocked, but they turn off immediately if locked.
Old 01-11-2016, 10:05 AM   #9
Giller's Avatar
How long are they staying on for? Do they eventually turn themselves off then? What's the time lag between taking out the key and the lights turning themselves off?
I know on my 986 - when I first got it it seemed as though the dash lights stayed on forever.
Old 01-11-2016, 10:06 AM   #10
They never turn off!
Old 01-11-2016, 10:55 AM   #11
The ignition switch is a cheap fix. If you're handy you can try swapping it out to see if it helps. If you have the radio playing when you shut the car off, does removing the key from the ignition shut it off?
Old 01-11-2016, 10:59 AM   #12
If the radio is playing, it turns off when I remove the keys.
I guess I will replace the electrical part of the ignition and see what happens.
Thanks,
Dave
Old 01-11-2016, 11:19 AM   #13
Thanks,
Dave
Hmm. Interesting. All I know is my odo stays on until I lock the doors. I hope the switch is the key, but maybe someone could weigh in elsewhere. Is there a micros witch somewhere that controls this?
Old 01-24-2016, 01:31 AM   #14
I found the problem. One of the stalks on the dashboard - the one that controls the clock - was pushed in and stuck. Sometimes the clock was flashing but most of the time it didn't. Once I took the dash apart and cleaned the stalk and put it back together the lights on the dash now go off when I lock the car.
Old 01-24-2016, 02:34 AM   #15
Good find Dave!
Deadeye is offline   Reply With Quote
Old 09-18-2016, 08:04 PM   #16
Gotta say...I've been in a lot of different forums...Ducati's, hot rods, etc...this is by far the most active and useful of any. I had this exact same problem...did a search for 'clock stays lit" and found the OP's issue and the cause was the sticking odometer stalk....easy fix and thanks to the OP and this forum.
ArizonaDan is offline   Reply With Quote
