Old 01-02-2016, 09:02 AM   #1
Coolant over flow tube
Replaced wp and filled new fluid. Fluid coming out of overflow and noticed around pressure relief valve. I am taking out fluid now. Have I damaged anything. Temp is perfect. No leaks at wp.
Thanks.
DWBOX2000 is online now   Reply With Quote
Old 01-02-2016, 12:34 PM   #2
Project Addicted
jcslocum's Avatar
I don't think anything is damaged but any overflow will end up under the cover around the coolant tank top. The drain drops the fluid in front of the right rear tire.
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
Old 01-02-2016, 01:36 PM   #3
THanks JC.
Old 01-02-2016, 02:04 PM   #4
Steve Tinker's Avatar
Don't forget to raise the pressure relief valve D shaped ring for 2-3 heat cycles to get rid of any air pockets hiding in the system too.....
2001 MV Agusta F4.
