Old 12-09-2015, 12:13 PM   #1
How to adjust front hood Help
I have a 2001 boxster s and you have to really slam down the front hood to close it
Is there a way to adjust this by any chance
Jimbo409 is offline   Reply With Quote
Old 12-09-2015, 12:35 PM   #2
911monty's Avatar
Shouldn't have to slam, just push down when you close it. That said several things to check. First check the hood height above the bumper cover, it should be about 1/16" below the level of the front bumper cover. To adjust screw the rubber bump stops on each side of the hood in or out to set the height. Once this is set there are 2 bolts inside the trunk that hold the latch loosen to adjust the latch height and left or right. If you need help or pictures let me know. It's real easy just takes a little fiddling to get perfect.
Old 12-09-2015, 02:36 PM   #3
911monty's Avatar
Here ya go Jimbo; The first pic is of the rubber bumpers. You can see the spiral cut that works as screw threads, clockwise shortens. use these to adjust hood height. Top of hood should be approx 1/16" below top of bumper, use credit card to check. This will keep wind noise down. since yours is hard to close this may fix your problem.
The next photo shows the 2 bolts that need to be loosened (just loose enough to move, don't remove) to move the latch assembly. Just pull the liner back to expose. It will make it easier if you pull the plastic trim piece from between the frunk and the bumper and expose the latch, but is not necessary.
Adjust the latch where just a firm push closes the hood. You may want to also check that the gap along the sides of the hood are right also. Let me know if you need more. Good Luck and enjoy.
Old 12-09-2015, 04:45 PM   #4
Hood
Thanks for the pictures
Old 12-09-2015, 04:48 PM   #5
911monty's Avatar
My pleasure. Let me know if i can be of any more help.
Old 12-09-2015, 04:59 PM   #6
Hood
Old 12-09-2015, 07:06 PM   #7
KevinH1990's Avatar
http://www.renntech.org/forums/tutorials/article/123-front-trunk-microswitch-replacement/
Here's an article on Renntech showing how to replace the front-trunk microswitch. It includes information on adjusting the latch. I think you need to be a member to access it.
Old 12-11-2015, 06:40 AM   #8
Pnut's Avatar
Nice! Gotta revisit mine and tinker with it. May look into new bump-stops as well.
Pnut is offline   Reply With Quote
Old 12-11-2015, 07:25 AM   #9
hood adjust
Was thinking if I put a washer under the hood stricker this might work,adjusting the latch uo doesn't work and it keeps the hood to high.I have it lowered and it seems like this is the right height for the hood but I have to slam the hood down to latch it.I will try and see what happens
Old 12-11-2015, 12:46 PM   #10
911monty's Avatar
Jimbo; If you can adjust the latch up enough to raise the hood above the trailing edge of the bumper, then you have plenty of striker. No need to install any shims. The latch can be adjusted in very minor increments, this is where finest comes into play. You may need to take some pics so we can see what's going on, but try this. Remove both rubber stops. Adjust the latch where the hood is closed and gap above the bumper is correct. Then install the bump stops to where they are just contacting the bumper.
