Old 12-07-2015, 03:52 AM   #1
Peer's Avatar
997 3.8L Carrera-S engine in a 986...?
If anyone has done a 997 3.8L Carrera-S engine conversion, please give me a pointer.
-- peer
Peer is offline   Reply With Quote
Old 12-07-2015, 04:10 AM   #2
What year 986?
Woody
Old 12-07-2015, 04:13 AM   #3
Peer's Avatar
1998.
-- peer
Old 12-07-2015, 04:34 AM   #4
I'm sort of in the same boat as you as I have a 2000 S. The 3.4 would be our easiest motor to swap in but the 3.8's hp is very intriguing. I don't have anything to add except that "101 projects for your Porsche boxster" goes into it a little bit. I'm hoping someone will chime in that has put a 3.6 or 3.8 in their early boxster.
Woody
Old 12-07-2015, 05:33 AM   #5
jb92563's Avatar
I suspect that the 3.4 is the same size case as a 3.2 but with bigger piston bore/stroke so is a relatively easy upgrade
I think the 3.6+ is physically a bigger engine so space and fitment will become more of an issue.
The ECU is also a higher version so wiring and sensors are more of a pain.
Like the other others are saying a 3.4 may be the easiest upgrade, 3.6+ and there will be more things that need to be adapted.
Someone has to be first and should document all those adaptations that are required.
I'm sure Jake has already created a higher displacement engine based on the 3.2 size case, which would be an easier option for fitment.
Old 12-07-2015, 05:41 AM   #6
Peer's Avatar
Yea, I'm kind of surprised that there's so little to find on the net, guessing that many of us 986-ers must have been drooling over a 3.8 conversion for years. No..?
-- peer
Old 12-07-2015, 05:54 AM   #7
-- peer
At least from what I've read the price of upgrading to the DME required along with the cost of the engine makes it entirely too expensive to be worth it. Especially from a 98. You'd be better off getting a Raby built engine as someone mentioned. And that will be expensive enough.
Old 12-07-2015, 05:43 AM   #8
Luv2Box's Avatar
-- peer
Peer,
I pm'd you with a number for a guy who did it.
Luv2Box is offline   Reply With Quote
Old 12-07-2015, 06:57 AM   #9
Peer's Avatar
While at it, I also have to ask if anyone has yet put in a TT 3.6..?
-- peer
Old 12-07-2015, 07:46 AM   #10
Be careful what you wish for; we had a customer that transplanted a Metzger Turbo engine into a 986. When finished, he ended up with a car that cost more than a new Turbo, was difficult to drive, and could shred driveline components at partial throttle.
Old 12-07-2015, 07:58 AM   #11
Well, i'm with JFP. If you want the power of a 996 TT, than buy a 996 TT. They are also available as convertibles. And the prices of these cars will be stable.
986 and 987 3.8 conversions have been done over here in Germany. But if you take a closer look at the costs and on the fact that nowbody will ever pay for the conversion if you want to sell the car, this just isn't a smart idea.
Regards, Markus
Old 12-07-2015, 08:10 AM   #12
The Radium King's Avatar
i'm amazed that someone hasn't done the arduino thing for variocam + engine conversions - so much easier than a full dme swap. I've heard of rpm-based on/off switches, but apparently not very smooth.
Old 12-07-2015, 01:50 PM   #13
Smooth enough for track work, maybe not for street. Kinda feels like a turbo kicking in at 3200 RPM.
Lon Tusler
1999 996, Track Only #996
Everything Jake could upgrade, and more!
ltusler is offline   Reply With Quote
Old 12-07-2015, 05:37 PM   #14
Pdwight's Avatar
Or Raspberry Pi....more capable than Arduino
Old 12-07-2015, 09:24 AM   #15
Chrono told me his "all in" price to upgrade his motor to a 3.8 was $18,000.
Old 12-07-2015, 09:33 AM   #16
BYprodriver's Avatar
-- peer
Search your answers are out there...
Old 12-07-2015, 07:41 PM   #17
i think the issue is coming up with the maps - did some reading on variocam + and it's three inputs (rpm, temp, load) with two outputs (cam duration, valve travel).
Old 12-07-2015, 07:46 PM   #18
Pdwight's Avatar
Someome
Will eventually do it
Old 12-08-2015, 06:31 AM   #19
hopefully - there seems to be a lot more open source info for the 7.8 dme vs the 7.2.
ps, sorry to the op for the hijack. 986/987/996/997.1 engines are physically interchangeable. the issue rests with engine management. partway through the the 9x6 evolution they changed engine management systems (from 7.2 to 7.8 canbus) and cam control (from variocam to variocam+). in order to put a more recent engine in an early 986 you need new engine management which means new wheel speed sensors, new abs controller, new brake lines, new hvac controller, new gauge pod, additional sensor wiring, additional canbus wiring, etc. - a big job. it would be nice if someone made a box that would run the new cams with the old engine mgmt system.
Old 12-08-2015, 12:51 PM   #20
GTA_G20's Avatar
I almost did this myself but it was a bit more daunting than I imagined once getting into assembling pieces.
Biggest issue is electrical. Our gen 1 boxsters 97-99 are 5.2.2 and dont have can-bus
3.6 and 3.8 engines run a 7.8 dme with Can-bus. You need to do alot of wiring (I bought a complete harness to add this bus system). You will also need an 2002+ speedo/cluster, abs controller, dme and engine. Headers also wont work. I bought '05 cayman s 3.4 full exhaust from someone who upgraded.
Its a big job
2006 Audi A4 Avant 2.0t Quattro
1997 Boxster Glacier White w/facelift(gone but not forgotten)
2004 Boxster S 550 Spyder Anniversary Edition
GTA_G20 is offline   Reply With Quote
