Old 05-05-2006, 05:49 AM   #1
Creaky clutch sound frim trans area
When I depress the clutch somtimes I hear a creaky sound from behind me, It happens regardless of if the engine is running ot not.
It's clearly at the trans and not the pedal.
Somthing I need to lube? (I hope!)
Marc Gelefsky
02 996 Carrera Coupe 6 Speed Aero
86 911 Carrera Targa
http://forums.rennlist.com/rennforum...tar14266_4.gif
EX-88 951, 87 951, 86 944na, 85.5 944na 00 Audi S4..01 Boxster S .etc..etc
Marc Gelefsky is offline   Reply With Quote
Old 05-05-2006, 06:49 AM   #2
Could it be the clutch spring for the pedal? Mine does this as well.
Old 05-05-2006, 06:57 AM   #3
It coming from the trans/Engine are, Not the pedal area.
Marc Gelefsky
Old 05-07-2006, 04:28 PM   #4
Mine had same problem..dealer said as long as clutch works nothing to do about it right now...
docdyh is offline   Reply With Quote
Old 05-07-2006, 06:22 PM   #5
I'm not sure if thats good or bad?
How long has yours been doing it?
Marc Gelefsky
Old 05-07-2006, 07:43 PM   #6
I have the same issue. My dealer told me that the creaking is just some dust from the clutch getting into the clutch cable housing or something like that. I was going to investigate some more before I did anything about it.
bohuslav is offline   Reply With Quote
Old 05-07-2006, 08:09 PM   #7
TriGem2k's Avatar
Send a message via AIM to TriGem2k
Just had it mine fixed last week...Your right it is coming from behind you and not from the pedal itself. Its actually the clutch slave cylinder that makes the annoying squeek.
-GT3 Front Bumper w/ Lip
-Side Skirts
-Gemballa Exhuast and Cats
-O.Z. Racing 18" Wheels
--18X8.5Front 18X10 Rears
-5mm Rear Spacers
-Porsche Door Sills
-H&R Springs
-Powerflow Intake
-B&M Short Shifter
-Focal Polyglass 165VR3
-Alpine PDX 5 Amp
-Audio Controld DQXS (DSP)
TriGem2k is offline   Reply With Quote
Old 05-07-2006, 08:12 PM   #8
Sounds as if your Dealer is feeding you a load of Bull. There is no Clutch Cable on a Hydraulic System. The only Cables your Tranny has are the Shifter Cables. You may have Dust building up inside the Bell Housing, but that much dust would tend to indicate that your Clutch will require replacement sooner than later at which time they'll do the TO Bearing and Pilot Bearing or Slave, these are most likely what you hear...
Happy Motoring!... Jim'99
Old 05-18-2006, 01:14 AM   #9
Any update?
Old 05-18-2006, 06:43 PM   #10
deliriousga's Avatar
If it's the slave cylinder, it's probably a trapped air bubble. My 928 had the same thing and a good bleeding of the system took care of it.
If your brake fluid has never been changed, you should get it done. It should be replaced at least every two years.
1966 Wife White/Brown Top
Old 05-19-2006, 03:17 AM   #11
its annoying as hell, but dealer said was normal wear.......been doing it for a long time...
