Originally Posted by bohuslav
I have the same issue. My dealer told me that the creaking is just some dust from the clutch getting into the clutch cable housing or something like that. I was going to investigate some more before I did anything about it.
Hi,
Sounds as if your Dealer is feeding you a load of Bull. There is no Clutch Cable on a Hydraulic System. The only Cables your Tranny has are the Shifter Cables. You may have Dust building up inside the Bell Housing, but that much dust would tend to indicate that your Clutch will require replacement sooner than later at which time they'll do the TO Bearing and Pilot Bearing or Slave, these are most likely what you hear...
Happy Motoring!... Jim'99
