Old 11-03-2015, 05:51 AM   #1
Will these wheels fit my Boxster?
I am considering a set of wheels pictured below (Not sure if these are the lobster claws or not). They are from a late model Boxster S and my vehicle is a 98 Boxster. Looking for some validation if these wheels will be a direct bolt on, or will I need spacers. (Pictures, Offset and Part #’s of the wheels in questions listed below)
Front:
235/40 ZR18 | 8Jx18 | Porsche Part Number 987 362 13600
Rear:
265/40 ZR18 | 8Jx18 | Porsche Part Number 987 362 13800
Thanks in advance for your input.
Current Vehicles: 85 Defender 90 Soft Top | 98 986 Hardtop + Red Interior | 00 Supercharged Jaguar XJR X308 | 2013 MB 250 AMG Package | 92 Range Rover Classic
Looking to add: Ferrari 328 GTS | Classic Rolls Royce
Britrover is offline   Reply With Quote
Old 11-03-2015, 06:18 AM   #2
On the slippery slope
JayG's Avatar
Front:
Rear:
What are the offsets? You did not list them
Are you sure they are both 8" wide wheels and the rear tires are 264/40 not 265/35?
2004 996 Targa Tip
Instructor - San Diego region
Old 11-03-2015, 06:39 AM   #3
Motorist & Coffee Drinker
78F350's Avatar
This thread is a little inconclusive,but has some more info on the wheels and includes the offset:
http://www.renntech.org/forums/topic/15074-boxster-s-987-18-rims-tires-on-98-boxster/
Old 11-03-2015, 06:40 AM   #4
Apologies, this is what I have been able to find from the web.
18x8 (57) & 18x9 (43)
Porsche Part numbers:
987-362-136-00 18x8
987-362-138-00 18x9
Checking on the tire size as it is probably not listed correct either.
Old 11-03-2015, 07:26 AM   #5
JayG's Avatar
here is a good caculator that you can compare the factory wheels/tires and others
Rim & Tire Size Calculator. Custom Offsets - Wheel-Size.com
or
http://tiwing.com/wheel-offset-calculator/
The wheel width and of set should be cast into the wheels. It may be around the valve stem
2004 996 Targa Tip
Old 11-03-2015, 08:42 AM   #6
Something you should be keenly aware of is the weight of the new wheels and rubber compared to your old ones, especially if you have to use spacers to get them to fit.
I have discovered the expensive way that fitting bigger heavier 18 inch rims on my 97 made it look great, but wore out the suspension parts prematurely not once but twice. And now I wonder what damage I've done to my wheel bearings with the extra weight on the hub.
Temper this comment with the fact that I bought aftermarket wheels and I think they're quite a bit heavier than factory Porsche wheels.
Old 11-03-2015, 10:06 AM   #7
Placed a call into Suncoast and these wheels will not fit my Boxster. The search continues.
Old 11-03-2015, 02:57 PM   #8
husker boxster's Avatar
Had to pull out a dusty piece of paper I have with offsets & widths. Factory 986 dimensions are:
7.5x18 (50)
8x18 (52)
You can use that as your starting pt when looking at wheel offset calculators.
I believe in 98 18s were a factory option but they weren't in 97.
1989 928 S4 5 spd - black
