Old 11-06-2015, 03:16 AM   #41
Project Addicted
jcslocum's Avatar
I have no good pics but this is one that does show the pipe in the engine bay from underneath:
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
Old 11-06-2015, 03:23 AM   #42
Project Addicted
jcslocum's Avatar
here's another that shows it on the inside of the engine bay. It should not run anywhere near the suspension on the outside.
______
Jon
1966 912, 1976 911
Old 11-06-2015, 07:26 PM   #43
flouese's Avatar
Thanks, appreciate the assist. Since I am changing out the master and slave cylinder tomorrow, might as well correct this problem.
99 Boxster base
1966 912 3 gauge
flouese is offline   Reply With Quote
Old 11-11-2015, 07:30 AM   #44
flouese's Avatar
Changed out MAF, throttle body, Idle air control valve, plugs and coils and this is the result (see attached cut and paste please)
https://youtu.be/b3EUB0dkTlg sorry about the door alarm sound!
I've looked for hoses that might have come loose when changing out the throttle body, all appear to be tight. Only saw a film of oil on the intakes to the throttle body. I can hear a loud sucking (HISSSSS) sound for the few seconds the car does run. Is this a possible O2 sensor issue? How do I check to see if the sensors are still good? Any assistance would be appreciated.
99 Boxster base
1966 912 3 gauge
