Old 10-26-2015, 12:49 PM   #1
mariosp's Avatar
Send a message via Skype™ to mariosp
replacing air filter with K&N
Hey gyus!!
What is your opinion about replacing the air filter with that?
http://www.amazon.co.uk/33-2773-Performance-Filter-Porsche-Boxster/dp/B00062Z0WA/ref=au_as_r?ie=UTF8&n=248877031&newVehicle=1&s=automotive&submodelId=16859
What are the actual benefits?
Marios
Porsche Boxster '04 weekend car
BMW X5 M sd '07 daily car
mariosp is offline   Reply With Quote
Old 10-26-2015, 01:12 PM   #2
Originally Posted by mariosp View Post
Hey gyus!!
In a word: None. Car may make more noise, but if there is too much oil on the filter it will end up on your MAF and cause problems. We have never seen any advantage to these filters, but have had to deal with their downsides. Stay with your throw away paper unit.
Old 10-26-2015, 01:15 PM   #3
98 Arctic silver 986
tommy583's Avatar
The benefits are none, other than getting a new MAF because the K&N is over oiled.
Old 10-26-2015, 01:23 PM   #4
mariosp's Avatar
more info on the specific filter can be found here
K&N 33-2773 Replacement Air Filter, Replacement Filters
Does nyone use it? how does it increase horsepower?
Marios
Old 10-26-2015, 01:42 PM   #5
On the slippery slope
JayG's Avatar
Yea, it give you 50 more HP
You can get 100 HP increase if you replace your blinker fluid
IF there is in fact an increase in HP, it is only due to a slightly increased air flow and therefore it is filtering less. Effectively it would have bigger holes in the filter material and that means larger dirt particles pass into your engine. Any (if in act any) HP increase is negligible at best
Stay with the paper disposable filter and check it at least twice a year, more if you drive in a dusty or dirty environment
2004 996 Targa Tip
Instructor - San Diego region
Old 10-26-2015, 04:00 PM   #6
See response from JFP in PA. Better yet, you should start using the search feature as I'm pretty sure this has been beaten to death.
Old 10-27-2015, 12:20 PM   #7
mariosp's Avatar
thank you all for your feedback!! I will stay with current air filter!!
Marios
Old 10-27-2015, 12:24 PM   #8
mariosp's Avatar
is there any safe way to increase the hp at least 5%?
Marios
Old 10-27-2015, 01:18 PM   #9
Ben-Auto-Design
Ben006's Avatar
Underdrive pulleys seem to have good results it terms of power gain.
Ben006 is offline   Reply With Quote
Old 10-27-2015, 01:54 PM   #10
PCA sticker on the windshield.
Old 10-27-2015, 05:17 PM   #11
Jager's Avatar
The Other Side
I use K&N in all my vehicles… It’s one of the first things I install. DO NOT SPRAY TOO MUCH OF THE TACKY OIL ON THE FILTER. LET THE OIL DRY BEFORE INSTALLING THE FILTER (I normally let it bake in the sun for a couple hours). I have never had to replace a MAF sensor, ever. I have over 282,000 miles on the Jӓgermobile and have not bought another air filter. I can’t imagine how many paper filters I would have bought by now.
Jäger
300K Mile Club
Old 10-28-2015, 02:26 AM   #12
DrCactus's Avatar
I replaced my paper one with a K&N last summer and it was great... I used barely any of the oil when installing it. You might be lucky to get 0.025% HP increase assuming your old filter was clogged up and not working properly.
DrCactus
