11-01-2015, 05:02 AM
#41
I am my own mechanic....
Originally Posted by jeeper31
So here is where I am.
Jumped the relay and still no pressure at the rail. Used multimeter to test to see if getting power at terminal 30 and I am getting 11.67 V at the terminal. So I am assuming the pump is bad since it is getting power and not working. Am I correct?
You made a jumper with one very thin blade to jump the FP relay terminals? Comes right on even with no key in ignition. Mine made a clunk but no fuel pressure. New one whirls smooth. You must know you're jumping the correct slots. If no pressure on the rail with correct slots jumped, it's FP. Make sure you go by the tiny numbers on the relay base, not the diagram on top of the relay.
There is an ohm test for the CPS. Don't remember the values off hand. They were posted in a thread I had about FP issues.
'08 VW Touareg T-3 wife's car
11-01-2015, 06:35 AM
#42
Suggestions:
1. Charge your battery 11.67v is a bit feeble.
Measure actual battery voltage at the batt terminals- is there a voltage drop at the FP relay?
Just thinking you may have poor connections between the battery and FP relay so that you get way less than 11.67v under load. Easy to eliminate as a potential source of problems.
2.If the relay did not click when you jumpered it:
1. relay is defective,or
2. connected wrong terminals
3. Remove relay and test. New relay is $10 :K.A.E. 2.408.120 ? 99661510100 For $10 at this stage why not just fit a new one?
See Pelican's excellent info: http://www.pelicanparts.com/techarticles/Boxster_Tech/22-FUEL-Fuel_Pump/images_med/Pic2.jpg
4. If you know what you are doing, connect FP direct to battery with a fused jumper cable.Polarity !
11-01-2015, 07:46 AM
#43
Originally Posted by Gelbster
Suggestions:
I didn't jump the relay I mean I jumped it at the box. It is a new relay. That's the first thing I did. The battery could be drained from me trying to start it so much.
11-01-2015, 07:54 AM
#44
Anything more than 9v 'should' operate the relay but why try? Just charge the battery to eliminate that problem. If you are measuring 11.67v with no load, it may be misleading because poor connections will show massive voltage drop when you draw power.
Did you bench test & compare the new & old relay?
11-01-2015, 08:19 AM
#45
How would I benchtest relay?
11-01-2015, 08:44 AM
#46
If you bought a new one, move on to the next possible issue. That's a done deal.
11-01-2015, 09:21 AM
#47
Google.#1 hit fo : "relay 12v test jumper bench"
https://www.youtube.com/watch?v=3JB63ebFfgU
Make sure the part number on your new relay is correct.If not, test the old relay and if good use it.
K.A.E. 2.408.120 or generic alternative verify for your yr.
11-01-2015, 11:41 AM
#48
Its either spark or fuel. To check for spark remove the little rubber hose that connects to the throttle body behind the throttle plate. At the hole, squirt wd40 into the throttle body at the same time you crank the motor. If the motor sputters and runs for a moment you have spark and the problem is fuel.
If you get no sputter then its a spark problem. Unless you have other ignition related codes, suspect the cps.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
11-01-2015, 02:32 PM
#49
I had no CEL with a dead FP. Just dead car. Perfect advise to check spark and rule that out.
Don't throw parts at it. Diagnose it. Where are you at in the process?
11-02-2015, 05:07 AM
#50
Took relay out and jumped spiral 30 and 87 at the box. Turned ignition on and checked for pressure on the fuel rail no pressure. Checked slot 30 at the box for power and there was power. Determined the FP was getting power and not running. Sounds like bad FP no? AM I premature in the diagnosis?
11-05-2015, 08:55 AM
#51
ok i am 90 percent sure it is the fuel pump. there is power going to the pump and the pump is grounded. However, i my journey to get to the pump i was taking the black hose off the sending unit )not the fuel line hoses) and i broke the white nipple off the fuel sender. Does that mean the fuel sender is done and I need a new one? From what i gather that could have been a $280 mistake.
11-05-2015, 09:44 AM
#53
I read the write up, don't think i missed anything. So it's time for a new fuel sender. How is the pump that comes with the kit. Looks like it got bad reviews. Intsonova is closed for now. He is dealing with huge fires in his area.
How the hell do you get the fuel lines from the pump off the fuel sender? I am cutting my hands up trying.
11-10-2015, 02:32 AM
#55
Here is the pic of the fuel lines. They are supposed to come off easily but i can't figure it out. How do I get these off?
11-10-2015, 03:29 AM
#56
Those connect to the fuel pump, don't they? They likely unclip from the FP.
11-10-2015, 05:28 PM
#57
They come off the fuel level sender. I just don't know how
11-11-2015, 01:50 PM
#58
Ok got fuel lines off.
Here is the part I broke. Wondering if I can glue it and if so what glue would be permanent?
11-11-2015, 01:53 PM
#59
A hack would be to use a coarse threaded brass nipple +epoxy.But if it failed after a few miles....
A good used pump may be wiser?
11-11-2015, 02:15 PM
#60
That's the fuel level sender. Buying a new Porsche pump but trying to save the $280 for the sender.
