Old 09-15-2015, 08:34 PM   #1
Boxster headlamp assembly internal wiring
2000 Box S with Litronics.
I had previously replaced my parking lights with LEDs, which matched my litronics nicely.
Went to swap out the fogs with H7 LEDs. Swapped with no problem but after swap, noticed that the pass. side parking light was out. I pulled assembly out to check the bulb and found that the insulation on mutiple wires was dried, cracked and missing! No wiring looked burned, just looked like the insulation had dried out and cracked away.
Anyone ever have this happen? I haven't pulled the drivers side to take a look...kind of want to leave it alone! Will post pics.
Old 09-15-2015, 08:46 PM   #2
pics
Old 09-15-2015, 08:57 PM   #3
Apologize for the pic size and double images. Been a while since I posted pics and I know (now) what I did wrong.
Old 09-15-2015, 08:59 PM   #4
ppbon's Avatar
Very common ...
... on most German headlights that are 10 years old or older.
Same issue in Mercedes Benz, Audi, VW.
Put some electrical tape on the frayed naked wires otherwise you will start blowing fuses and damaging the lights switch.
Happy Boxstering
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
Old 09-15-2015, 09:11 PM   #5
Yep.
75% of all the headlights that I work on need all of the wiring replaced. I hate it. So much.
Be careful with the fog lights. If the insulation is brittle and falls away when you move the connector, it's very difficult to get to without opening the headlight.
particlewave is online now   Reply With Quote
Old 09-16-2015, 09:20 AM   #6
lkchris's Avatar
New German regulations from mid-1990s-on require biodegradable wiring harnesses.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
Old 09-16-2015, 09:25 AM   #7
lkchris's Avatar
OsramŽ All-SeasonŽ Selective-Yellow Tint H7 55w Bulb
Kent Christensen
Albuquerque
2001 Boxster
2 BMW motorcycles
Old 09-16-2015, 11:38 AM   #8
I'd just never seen this pop up of the forums before. I used liquid electrical tape but plan to go in and replace the damaged wiring.
Old 05-24-2024, 04:59 PM   #9
Anyone else repaired this? I am thinking either liquid electrical tape or heat shrink tubing. Thoughts?
01 Boxster S 6Spd, Speed Yellow w/84k miles. | 991.1 911 C2 7spd Manual | 01 996 C2 -6spd - Green Machine - My baby | 997.2 C2S 6spd | 2x 01 Boxster base
professorman is offline   Reply With Quote
Old 05-24-2024, 05:07 PM   #10
You can buy remade wiring harnesses
https://www.adriantaillights.com/store
spinjockey is online now   Reply With Quote
Old 06-02-2024, 06:21 PM   #11
I pulled the harness completely out of both sides and crimped in new wire one length at a time. About a month after I did, I saw someone post the replacement harness site- if I had seen that before starting, would have bought the replacements without a second thought.
Hasdrubal is offline   Reply With Quote
Old 06-02-2024, 07:19 PM   #12
I need 4 for my two Boxsters. I am painfully doing them 1 wire at a time. I am soldering in new wire and using heat shrink tubing to cover sections that I can’t reach, as well as my solder connection points. I might make a video. I’ve done 1 headlight out of my 4 so far.
Old 12-25-2024, 02:04 PM   #13
CVBoxster
Smile
Glad I saw this! I had started to replace wire by wire... will order the kit right away. Thanks!
_____________
RAF
00 S Arctic Silver
Go and See
rafibanez is offline   Reply With Quote
