Old 09-12-2015, 04:56 AM   #1
Anyone know this locknut key code??
We tried welding but snapped and then again. Car not on road atm so can't get to a dealer. Any ideas??
padsf1 is offline   Reply With Quote
Old 09-12-2015, 05:16 AM   #2
I am my own mechanic....
Timco's Avatar
Pound a socket over it?
That's how we used to steal....er, uh, help...buddies with their own when socket was lost.
'08 VW Touareg T-3 wife's car
Old 09-12-2015, 05:41 AM   #3
Tried that but can't seem to find any size that fits close enough to bang on . Any ideas of sizes?
Old 09-12-2015, 10:02 AM   #4
Anyone else know the code?
Old 09-12-2015, 12:26 PM   #5
They do make a set of threaded sockets that thread themselves on to the OD of the wheel lock as you try to remove the wheel bolt.
I had to use a set to remove a wheel after a ham handed tire tech used an impact to torque my wheel bolts on.
They work great but it is a B***H getting the socket off the wheel bolt after it has been removed from the wheel.
emore93 is offline   Reply With Quote
Old 09-12-2015, 03:51 PM   #6
Master Brewer
Bootlegger's Avatar
That looks like the same one that I have. Where do you find the code??
____________________________________
2004 Boxster S Anniversary 550 Spyder
2018 Porsche Macan (wife's ride)
2004 Ford F-150 4X4 Crew
6 Fast Bicycles
Bootlegger is offline   Reply With Quote
Old 09-12-2015, 11:02 PM   #7
You find code either wrote on the plastic bag that the locknut came in and also on the option card if the mech decided to write it on there on delivery of car.
Old 09-12-2015, 11:39 PM   #8
amagalla's Avatar
go to the dealer. You can get a new one if it's a factory lock.
Lapis Blue 03 Boxster S
Old 09-13-2015, 05:10 AM   #9
23 mm (not an impact socket)
I have to use a socket on about 25% of the cars that come into my yard because the key is missing. Hammer it on, break the lug bolt loose, and before you loosen it all the way. Take your hammer and tap it around the edge. The socket should work it's way off. I also start with that lug bolt, before removing the other four lug bolts.
Woody
Old 09-13-2015, 02:52 PM   #10
Motorist & Coffee Drinker
78F350's Avatar
...What Woody said.
And for me, a medium depth 12 point 11/16 socket has pulled 8 bolts so far and should be good for a few more.
