Old 09-08-2015, 04:50 AM   #1
DIY fix for lose underside plastic panels???
Hi
I posted recently about a rattle I've started hearing on my 2007 when I hit 65 mph. I had the mechanic take a look and he said some of the fasteners on the plastic shields under the car had come loose. Apparently they had taken a shot from a speed bump or something like that and the certain fasteners were damaged. Can you order replacement shields and are they really expensive ? Alternatively, has anyone had any luck securing them some other way? Like with Zip ties for example?
lurky is offline   Reply With Quote
Old 09-08-2015, 05:30 AM   #2
I am my own mechanic....
Timco's Avatar
You can buy an undercarriage panel attach kit or whatever they call it and it has all the plastic nuts and clips and washers.
The panel under my engine was 150.
'08 VW Touareg T-3 wife's car
Old 09-08-2015, 09:10 AM   #3
The under panels aren't too expensive. I bought these at Sonnen Parts for my 2000 Boxster: 2000 Porsche Boxster Parts - Porsche OEM Parts - Genuine Factory Parts Accessories - Wholesale
jklaspok is offline   Reply With Quote
Old 09-08-2015, 11:03 AM   #4
1998 Boxster Owner
Originally Posted by lurky View Post
Hi
I noticed mine hanging the other day...when I inspected it the previous owner was keeping it together with steel/metal wire. Zip ties should work as a temporary fix. Now that I know what I know I will likely order one some time in the future.
Benitom is offline   Reply With Quote
Old 09-08-2015, 11:27 AM   #5
98 Arctic silver 986
tommy583's Avatar
I have had one of my rear panels held on with a zip tie for 3 years. I just tied it around the aluminum brace.
Old 09-08-2015, 11:27 AM   #6
The next owner of your car will appreciate the job done right.
Most of the components are available. Take a look here to find the PN's that you need: 986 Underbody Components
