Old 08-24-2015, 11:11 AM   #1
CrisZenithBlue's Avatar
help needed to diagnose bearing noise
2000 base 2.7L with 118k miles.
started hearing what sounds like bearings going bad from the belt area and pulled the cover to try and pinpoint it.
here's a video of the noise:
https://www.youtube.com/watch?v=hSXYJ4XiuTM
sounds to me like a belt tensioner, it looks like its coming from the center area not the left (alternator), right (AC), or below (water pump - replaced 10k miles ago)
what do you guys think?
also, is there a tensioner kit i could buy? i'd rather change all of them (dont think they've ever been changed). belt was replaced 1k miles ago, it starter shredding itself to bits and i caught it before it completely snapped.. phew!
i know i can also just change the bearings for less but not sure how much of a hassle that is since i dont really have more than basic tools.
CrisZenithBlue is offline   Reply With Quote
Old 08-24-2015, 11:13 AM   #2
EJ-Fresno's Avatar
Some tensioners are on sale at ECS Tuning for now.
One of them is like $40, instead of $80...
2003 2.7 Boxster - Tiptronic - Carrera wheels - OBC - Red calipers - Cat pipes - Modified muffler - Rear speakers - K&N - Litronics
2006 V6 Mustang
2008 ML 350
EJ-Fresno is offline   Reply With Quote
Old 08-24-2015, 12:54 PM   #3
epapp's Avatar
Take the belt off and spin the pulleys by hand. It will be obvious which is bad.
epapp is offline   Reply With Quote
Old 08-24-2015, 01:02 PM   #4
are they all the same size? there's 3 of them if i recall correctly.
40$ is a great deal i will look into it!
Old 08-24-2015, 01:06 PM   #5
good point and i have thought of it but i figured i didnt want to go through the trouble of taking off the belt (a bit of a PITA to put back from what i heard). since i believed i need some pulleys might as well get a full set and take the belt off when replacing.
Old 08-24-2015, 01:32 PM   #6
epapp's Avatar
The belt is probably one of the easiest things to take off and put on IMO. Only second to taking out the headlights...
Old 08-25-2015, 06:02 AM   #7
ok so i got off my lazy ass and took the belt off this morning before going to work to find the culprit. it's the tensioner pulley that's causing all that racket! it has a lot of resistance when spinning, more than the other idler pulleys.
got the part from ECS for 50$ shipped. (thanks for the tip EJ! )
epapp you were right, the belt is so easy.. not sure where i got the idea it's a pain. I feel pretty silly i didnt do this in the first place.
thanks guys!
