Old 08-18-2015, 03:09 PM   #1
FirstPorsche
firstporsche's Avatar
Rear trunk not opening, suggestions?
Hi all,
2002 Boxster. Owned for 8 years. Suddenly the rear trunk stopped opening by either the fob or the door switch.
The frunk works fine by both the fob and door switch.
Could this be a fuse issue? Don't know if they are both on the same fuse, but it seem probable, which would rule out a fuse.
Any bright ideas?
2002 Boxster 986
2010 VW GTI
firstporsche is offline   Reply With Quote
Old 08-18-2015, 03:12 PM   #2
epapp's Avatar
No value added: being on the same fuse would make anti-sense. Then if one failed or shorted, both would be dead!
epapp is offline   Reply With Quote
Old 08-18-2015, 03:28 PM   #3
Fuse D7 (same as spoiler). My guess would be bad actuator. If it is a bad actuator, you'll have to use the emergency release cable (I believe it's behind the rear bumper cover).
Old 08-18-2015, 05:25 PM   #4
thom4782's Avatar
My 01S had similar symptoms: 1) fob wouldn't open the trunk and 2 neither would the switch located to the right of the driver seat.
It turned out that the cable from the driver's side switch to the trunk locking mechanism in the rear had failed where the wire connects to the actuator. The solution was to: 1) open the trunk using the emergency release and 2) crimp on a new wire loop to reconnect the end of the old wire to the actuator.
Since the local indie did the work, it only charged for an hour's worth of labor. If it had to replace the part, the labor cost would have gone up and, of course, then there would be the cost of the part.
BTW: This was really easy to do because I had relocated the emergency release cable to the driver's side bumperette when I had the rear bumper cover off for some prior work. In now takes about 30 seconds to remove the bumperette and pull on the cable to open the trunk
Hope this helps
Old 08-18-2015, 07:45 PM   #5
My 01S had the same problem last Autumn. Indy had to replace the actuator, not just reconnect the cable. What a pain.
DBear
dbear61 is offline   Reply With Quote
Old 08-19-2015, 07:22 AM   #6
FirstPorsche
Amazing! Nobody could ask for faster, more cogent advice. Thanks to all who chimed in on this. Unbelievable resource! Porsche owners are #1 in my book!
2002 Boxster 986
2010 VW GTI
Old 08-19-2015, 04:03 PM   #7
2002 Boxster S
But test the fuse first: the spoiler is on the same fuse, so if you try to raise the spoiler by the switch by your left foot, under the fusebox, you'll soon know whether the fuse is gone.
2009 Carrera S cabrio
ex-2002 Boxster S, Arctic Silver, Aerokit II
silver-S is offline   Reply With Quote
Old 08-23-2015, 05:42 AM   #8
wow i discovered my remote works the hold button to open trunk worked Ive always thought mine was broken also
orioner00 is offline   Reply With Quote
Tags
fuse , trunk , trunk lid release
