Old 08-06-2015, 04:16 PM   #1
Goth Popper
99 Boxcutter's Avatar
Blinking red light
Hey guys, I just got the blinking red light of death so I pulled over immediately. Boxster has been running fine but earlier today I used one of those arctic freeze AC recharge kits from Autozone... I don't know if that has anything to do with it .
www.appleneworleans.com
99 Boxcutter is offline   Reply With Quote
Old 08-06-2015, 04:19 PM   #2
epapp's Avatar
I know over pressurization of the AC system is a thing, but I'm not sure if it triggers the RLOD. You are talking about the CEL and not the coolant slow blink, right?
epapp is offline   Reply With Quote
Old 08-06-2015, 05:29 PM   #3
What blinking red light of death are you talking about? The CEL when blinking is the yellow light of death...
clickman is online now   Reply With Quote
Old 08-06-2015, 05:49 PM   #4
There Is No Substitute.
rick3000's Avatar
I think you mean the Change Engine Light.
I kid. Borrow a diagnostic tester from AutoZone and see what code it throws up. Not really enough information to diagnosis this.
Old 08-06-2015, 08:01 PM   #5
Goth Popper
Well it stopped... To be fair, it was 95 degrees today and this isn't the fist time I got the RLOD. Using the tester will be my next step.
Old 08-07-2015, 07:43 AM   #6
Rob175's Avatar
IF it was the red light located near the coolant temp gauge then you need to add coolant (50/50 anti-freeze + water)....... Might need to also replace your coolant cap with the newer "improved" sealing cap.
Rob175 is online now   Reply With Quote
Old 08-08-2015, 10:12 AM   #7
No, my Change Engine Light is on my IMS Guardian.
