12-23-2018, 07:02 AM
#61
Second tank, 17mpg from ~ 105mi city, ~50 fwy.
I need to check the air filter, and track the fuel trims.
'99 986 Base
2010 Golf TDI
'74 914 2.0
'56 356A
12-23-2018, 07:35 AM
#62
1997 Tip, 2018 Macan
I have driven 17573 miles in just over 3 years. I am at 20.66 Avg MPG. Keep your tires at proper pressures and stay up on the maintenance. I think you are in the ballpark. How spirited do you drive? I have had tanks that measured low at +/-16 and high at just over 23. Safe travels.
12-23-2018, 01:09 PM
#63
My 2000S 6sp would get 17-18 around town and 28 on the highway.
12-23-2018, 10:17 PM
#64
Tailwind, Sounds about right, I have an 01S, I get 15-18 in city driving with really bad traffic and have gotten 25 on highway to Reno.
12-26-2018, 05:08 AM
#65
I also had this question, and found this thread:
How many miles on a tank typically?
A lot of perspective from forum members.
'99 986 Base
2010 Golf TDI
'74 914 2.0
'56 356A
12-26-2018, 08:56 AM
#66
I get about 16-18 MPG city and if I'm lucky 20-22 Hiway; same as my 5,115 pound Toyota Landcruiser
5280 Cruising @High Altitude
Seal Gray & K&N Filter
12-26-2018, 09:13 AM
#67
Hm,
i have to convert from Liter / 100 Km to mpg.
My average consumption is around 10 Liter / 100 Km, which converts to 24 mpg.
Lowest i got was around 8.5 Liter / 100 Km, which converts to 28 mpg.
If i push the car hard, it's around 12 Liter / 100 Km, which converts to 19.5 mpg.
On the Autobahn at higher speeds above 200 Km/h and more up to vmax it was around 15 Liter / 100 Km, which converts to 16 mpg.
Don't know what you do to get such bad mpgs in general.
12-26-2018, 09:53 AM
#68
It ain't a Prius, don't drive it that way. Once warm, an "Italian tuneup" every once in a while.
Of course, how fresh are the coil packs and plugs?
12-26-2018, 05:33 PM
#69
It seems to me first thing is to verify your calculation. Run through a full tank and I would double check the miles driven with a GPS to make sure the odometer is within reasonable limits.
Grant
01-16-2019, 11:29 AM
#70
Just getting on the freeway, the reserve light came on. After a 35 mile round trip, the needle was half way between Empty and Positively. 14 gal fill with 276 on the Odo = 19.8MPG mixed driving, more freeway this tank.
'99 986 Base
2010 Golf TDI
'74 914 2.0
'56 356A
