Old 07-30-2015, 09:30 PM   #1
No music!...
So I'm cruising along top down listening to my music jammin' to the beat when all of the sudden... silence. The radio is still on as I can see the radio station but nothing coming out of the speakers.
The manual says I have an amp in the front trunk. Is it common for these to go bad? Blow a fuse? I may use this as an opportunity to go aftermarket.
Any feedback would be appreciated!
Cebu is offline   Reply With Quote
Old 07-31-2015, 05:23 AM   #2
Joe B's Avatar
Sometimes my original Bose radio fails to turn on, although it lights up with word "Porsche." If I press the CD button with no CD in, that seems to wake it up. Might be worth a try. Let us know what works.
Old 07-31-2015, 06:11 AM   #3
Multi-Boxer Driver
Deserion's Avatar
On rare occasion mine won't work though it powers up. Here's my process:
1. Turn off car and remove key
2. Open driver's door, then close it
3. Lock with key fob
4. Unlock with key fob
5. Open and close driver's door
6. Restart car
7. ????
8. Profit
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 07-31-2015, 06:42 AM   #4
Chuck W.'s Avatar
I would pull the radio (very easy with the below tools) and check the rear connectors. It is rare that amps just die like that. Also, plug in a CD (or cassette) and see if that portion works.
1995 Porsche C4 Cab
Old 07-31-2015, 06:58 AM   #5
Giller's Avatar
While it wasn't a regular occurrence for me, it did happen a couple times. Just stopped playing, but the display sure looked like it was still on. Eventually returned on it's own after a couple starts and stops.
Old 07-31-2015, 07:20 AM   #6
schnellman's Avatar
What?
My Boxster has a radio? Wow, I'm always listening to the Flat 6 Symphony.
Old 07-31-2015, 07:22 AM   #7
pony13ca's Avatar
Mine would do that every once in awhile. If i just took the face plate off, and then put it back on. It would start to work again. Ended up going after market, so I would have Bluetooth.
pony13ca is offline   Reply With Quote
Old 07-31-2015, 08:48 AM   #8
Chuck W.'s Avatar
Originally Posted by pony13ca View Post
If i just took the face plate off, and then put it back on. It would start to work again. .
I forgot about this. pony13ca is right. Take the faceplate off and wipe off the contacts on the faceplate and radio. Great call.
1995 Porsche C4 Cab
Old 08-03-2015, 05:29 PM   #9
Good evening fellas,
I tried the suggested feedback except removing the faceplate? Does the faceplate actually come off? My faceplate will pop open downward so you can access a cassette opening.
I hope the output stage of the radio or amplifier didn't go kaput.
Old 08-13-2015, 07:12 PM   #10
Just a follow up. I actually had a chance to mess with the car this evening. The Bentley manual showed the amplifier 15A fuse location D9. I checked it and sure enough it was blown. I replaced it and the amplifier came to life.
If it happens again I'll have to troubleshoot further. When the fuse blew the ambient temperature was over 100. Perhaps the amp became to warm? Reaching now..
