Old 07-20-2015, 09:47 AM   #1
ABS pressure sensor
Hi-
On my 986 the abs pressure sensor has failed - on the car the whole part incl the pump is number 98633575544 - it looks like the pressure sensor bit is a separate "screw in" but it isn't listed as such on the porsche parts list.
Does anyone know if this sensor can be found separately from bosch or elsewhere, perhaps its the same part as used in another car -
I understand that the 987 pressure sensor is housed inside the whole unit -
thanks
rossa123 is offline   Reply With Quote
Old 07-20-2015, 12:46 PM   #2
In the past, there were reports that a malfunction of the stoplight switch could cause a fault that appeared to be a failure of the switch itself. Have you verified that it is indeed a failure of the pressure switch?
