Old 07-17-2015, 06:26 AM   #1
Exclamation Windows will not roll up after top repair. SOLVED!
Greetings,
A little background info first. Yesterday, I repaired the 2 cracked threaded brass inserts on the top center of the windshield with steel rivnuts. After putting everything back together, the windows will not go up. I figured I would ask the masses first, anyone experience anything like this before?
UPDATE: It seems to also affect the ignition. I will get gauges, lights, radio etc., but nothing when I turn the key. After a few tries, it will start, but if i turn it off, same thing
PROBLEM SOLVED! Was looking at the wrong fuse. Replaced fuse and all is well. Nothing to see here (embarrassed) Move along.
Defectfully
Patrick
Hogosha is offline   Reply With Quote
