Windows will not roll up after top repair. SOLVED!
Greetings,
A little background info first. Yesterday, I repaired the 2 cracked threaded brass inserts on the top center of the windshield with steel rivnuts. After putting everything back together, the windows will not go up. I figured I would ask the masses first, anyone experience anything like this before?
UPDATE: It seems to also affect the ignition. I will get gauges, lights, radio etc., but nothing when I turn the key. After a few tries, it will start, but if i turn it off, same thing
PROBLEM SOLVED! Was looking at the wrong fuse. Replaced fuse and all is well. Nothing to see here (embarrassed) Move along.
Defectfully
Patrick
