Old 09-12-2015, 02:14 PM   #1
New window regulator but glass still hits convertible frame.
So I installed a new window regulator because my window glass kept hitting the convertible frame. Now it does it 50% of the time. Sometimes it will work perfect and sometimes I have to hold the handle open and let it go just as it touches the rubber seal. If I let go of the handle the window just goes all the way up. Any suggestions???
GatorLapis is offline   Reply With Quote
Old 09-13-2015, 12:18 PM   #2
Can Anyone help me with this issue?
Old 09-13-2015, 12:56 PM   #3
That's most likely a faulty door lock/latch mechanism microswitch.
The door handle microswitch tells the car that you are opening the door, so it rolls the window down slightly. The door lock mechanism tells the car that the door is closed and to roll the window back up. I believe you have to replace the whole lock mechanism.
Check with Woody (member itsnotanova). I bet he could set you up with a good used one fairly cheap
Old 09-13-2015, 05:45 PM   #4
thank you!
Old 09-13-2015, 07:15 PM   #5
Motorist & Coffee Drinker
78F350's Avatar
I'm having a busy Boxster weekend and took care of a few items on my old-neglected Black '99 (AKA "Dirty").
Here are some pictures to help illustrate the procedure that particlewave mentioned.
Between these pics and the Pelican Parts Tech Articles, it should be almost easy.
Porsche Boxster Door Panel Removal / Mirror Switch Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article
Porsche Boxster Door Lock Mechanism / Door Handle - 986 / 987 (1997-08) - Pelican Parts Technical Article
Putting it back together: I recommend latch first, then lock lever, then handle.
Good luck :dance:
