Old 06-14-2015, 11:11 AM   #1
Exhaust bypass pipes and Transmission boot identification
Gents,
My "inexpensive" muffler and accompanying bypass pipes have never had the greatest "fit" and finish on my car... was tired of staring at my exhaust tips pointing in at each other, and also wanted to fix a bunch of exhaust leaks at all the connections.
Need some advice on if you think this is "adjustable" by a muffler shop. You can see on the driver's side pipe that the angle is off a bit from the cat and it's pushing into the transmission/bracket thing (not sure what that is). I want to correct this, but not sure if a muffler shop would be able to fix the angle on the pipe.
My other question is on the side of the transmission (it's a Tip), there's a rubber boot on what appears to be the shift linkage. This is now in 2 pieces and cracking a bit. Anyone know the part number on that?
stateofidleness is offline   Reply With Quote
Old 06-14-2015, 11:21 AM   #2
I am my own mechanic....
Timco's Avatar
I welded flat, bolt together flanges to my 'u shape muffler adapter to pipes" connection. Sounds way better. A decent muffler or welder guy can make any of that stuff line up.
'08 VW Touareg T-3 wife's car
Old 06-14-2015, 01:16 PM   #3
Pdwight's Avatar
Wow
That is a clean underside
Old 06-14-2015, 02:13 PM   #4
gets cleaned regularly!
Old 06-14-2015, 02:38 PM   #5
Pdwight's Avatar
Actually
That would be a great DIY project to get posted...technique, chemicals etc
Old 06-14-2015, 05:38 PM   #6
It only cost me about $9,000 to get it that clean lol!!
The joke behind that is that I had to have my transmission rebuilt (talk about an ordeal!!!!) - anyways, it's basically brand new, and I feel like I've replaced everything under there at some point as well.
Just became part of the "maintenance" to keep it that clean - wiping it down often with old rags (read: underwear), and elbow grease!
