Old 05-31-2015, 05:29 AM   #1
Blacklight's Avatar
Chirping/squeal from engine
Just got 1989 2.5l. Have this annoying sound, previous owner had water pump and
Alternator switched. No coolant leaking onto belt and he says spark plugs not loose.
Apart from this car seems to run OK, drives well but doesn't start well in the cold. Alarm system also a pain, being set off by the slightest thing. It's really windy today so it keeps going off. Can it be disabled, or made less sensitive?
Hope someone out there has some other suggestions on the chirping noise, it's a real nuisance!
Blacklight is offline   Reply With Quote
Old 06-02-2015, 12:51 PM   #2
98 Arctic silver 986
tommy583's Avatar
I would still check all the spark plugs. That is the cause of chirping most of the time.
Old 06-02-2015, 01:27 PM   #3
Blacklight,
For the chirp/squeal - Inspect the big drive belt for the ancillaries. Look very carefully at the edges for fraying &/or dirt in the grooves.
If one edge of the belt is frayed, suspect that idler pulley bearings may be wobbly?
Use a stethoscope with the engine running to isolate the source? Careful!
Remove the belt entirely and run the engine briefly to hear if that eliminates the noise.
Place a straightedge across adjacent pulleys to observe their alignment. I found two of mine had new bearings but the bearings were slightly canted. This caused both idlers to wobble.Not good.
Old 06-02-2015, 01:36 PM   #4
I am my own mechanic....
Timco's Avatar
Remove the belt and run it for a few. See if still makes noise.
'08 VW Touareg T-3 wife's car
Old 06-09-2015, 12:30 PM   #5
Blacklight's Avatar
Despite assurances that plugs were the first thing checked. I put car into local performance car specialist. Spark Plugs!!!! Every single one loose and charred to a crisp!
Car now runs without squeal. My next question is creaking from steering? Car just passed UK MOT safety test ( compulsory). So I know it's safe to drive, however, steering creak is concerning me
Old 06-09-2015, 01:11 PM   #6
tommy583's Avatar
Glad you found the cause of the chirping. I'm not sure about the steering noise.
Old 06-09-2015, 02:17 PM   #7
Blacklight's Avatar
Should say, I'm new to Porsche. Have AMG Merc as main car, and have previously owned Audi and Honda (never again!, too expensive to run for what you get. Honda that is!) Their bikes are excellent though but if it comes to two wheels, better to go BMW. My First Boxster is a 1998 2.5L and so far it's really been fun. Wife loves it.
Old 06-11-2015, 08:40 AM   #8
landrovered's Avatar
My boxster made steering growling noises, the fluid level was not really low so I overfilled it with Pentosin and the noise went away. That was 8 years ago. Haven't heard it since.
2001 Boxster S 3.6L, Zeintop
"Calling upon my years of experience, I froze at the controls." - Stirling Moss
landrovered is offline   Reply With Quote
