Old 06-05-2015, 01:50 PM   #1
986 Top doesn't open - help!
Windows don't drop, clamshell doesn't move. Checked fuses, removed and reinserted relay, tried alternate relay, replaced microswitch for the latch receptacle, and the e-brake light does come on. I've tried being a little rough with the e-brake as well, and manually trigger microswitch to no avail.
ideas? I don't even mind having to manually move it, I'd just like to get the clamshell open for servicing and sunny days.
chromecarz00 is offline   Reply With Quote
Old 06-07-2015, 05:25 AM   #2
Pominoz's Avatar
sounds like you have ruled out all the switches. Maybe you've got a bad connection in the wiring somewhere. Mine was the parking brake switch when I had that problem, at least yours isn't stuck open though
Boxster Base, 2002 Manual, Black.
LN Single Row Pro IMS retrofit.
Pominoz is offline   Reply With Quote
