Old 06-04-2015, 08:23 PM   #1
Low friction rings
I believe that our low friction piston rings require engine vacuum to seal and perform properly, would be then safe to say, that if you have a vacuum leak your engine would not be producing 100% of it's power?
after replacing a leaking (cracked AOS, accordion hose), now the engine does it seems to run smother and more powerful, does this makes sense..?
My 3.4 engine has a bit over 80k..
Last edited by Gilles; 06-04-2015 at 08:25 PM. Reason: PS: please pardon my English
Old 06-04-2015, 09:21 PM   #2
BYprodriver's Avatar
They are low tension rings against a low friction cylinder wall, but yes vacuum leak could cause slight loss of ring seal. Leaner air/fuel ratio from eliminating "false air" getting into intake without flowing thru the mass air sensor, is probably biggest reason for the improvement.
Old 06-05-2015, 02:47 PM   #3
+1 What ^^^^ said.
Old 06-05-2015, 03:25 PM   #4
Yes, it makes sense..!
My car must be running better now because it has the correct mixture.
I was getting about 20mpg, I will see after the next tank if something changes with the mpg, thanks again!
