Old 06-02-2015, 05:28 PM   #1
embryoguy@mac.com's Avatar
small squeak at start
I occasionally get a small squeak from engine at start and it last for about a few minutes. Any thoughts? Thank you.
embryoguy@mac.com is offline   Reply With Quote
Old 06-02-2015, 05:31 PM   #2
Fintro11's Avatar
belt slipping ?
Old 06-02-2015, 05:37 PM   #3
i have no clue. its a subtle sound and most might not even notice it. high pitch sound though. but as mentioned, after a couple minutes its gone. maybe timing belts are just off?
Old 06-02-2015, 05:47 PM   #4
Need For Speed
KRAM36's Avatar
I'd check the Secondary Air System pump.
2003 Boxster S
Old 06-02-2015, 06:03 PM   #5
i have no clue how to check that is it critical if its an issue there? should i get it check out? thank you
Old 06-02-2015, 07:00 PM   #6
I am my own mechanic....
Timco's Avatar
Belt
Beginning WP failure
Beginning alternator failure
Belt pulley getting loose.
Any of these things will make noise then go away when warm.
'08 VW Touareg T-3 wife's car
Old 06-02-2015, 08:37 PM   #7
Steve Tinker's Avatar
+ a loose spark plug....
Belt slipping ?? I doubt it. Have you felt the pressure the tensioner exerts on the belt?
2001 MV Agusta F4.
Old 06-03-2015, 04:08 AM   #8
kk2002s's Avatar
The Secondary air pump(SAP) runs at cold start for about 1-1/2 - 2 minutes (Sounds like small vacuum)
If your high pitch sound is during that and goes away when pump stops, indications are bearings in SAP are dry (They can be re-greased)
Obviously if the sound is not associated with SAP then check previous posters suggested components
Seal Grey
Old 06-03-2015, 04:22 PM   #9
ok Thanks guys I have it looked at. KK I think you your description is exactly what it sounds like.
Old 06-03-2015, 05:22 PM   #10
EJ-Fresno's Avatar
I think I have the same issue, a kind of whistle for a few seconds at start-up...
Is it difficult to re-grease those bearings?
2006 V6 Mustang
2008 ML 350
EJ-Fresno is offline   Reply With Quote
Old 06-04-2015, 04:04 AM   #11
kk2002s's Avatar
There is a write up some where. Not sure if it's this forum or another
It's not hard, the pump comes apart and the bearings are accessible.
I used a grease gun with a needle adapter. It is a bit difficult getting around the seals to get grease into the bearing but can be done
There are (3) rubber isolator fitting that attach the pump to the engine. I have one that tore so be careful removing and inspect.
I ordered 3 @ $ 9.70/each but was informed that only supplier now charged $27/each
Grainger sells for around $3-$4 each
Seal Grey
