Old 06-04-2015, 05:04 AM   #11
kk2002s
kk2002s's Avatar
There is a write up some where. Not sure if it's this forum or another
It's not hard, the pump comes apart and the bearings are accessible.
I used a grease gun with a needle adapter. It is a bit difficult getting around the seals to get grease into the bearing but can be done
There are (3) rubber isolator fitting that attach the pump to the engine. I have one that tore so be careful removing and inspect.
I ordered 3 @ $ 9.70/each but was informed that only supplier now charged $27/each
Grainger sells for around $3-$4 each
Seal Grey
