Old 05-26-2015, 08:34 AM   #1
2 fast 4 U
OEM Coolant Expansion Tank
Where is the best place to get an OEM coolant expansion tank. Has anyone used the tanks sold buy Vertex auto? I can't believe I can't find a tank at a reasonable price.
Drive it the way it's meant to be driven!
2000 Boxster S
redeye280z is offline   Reply With Quote
Old 05-26-2015, 09:53 AM   #2
2 fast 4 U
Also want to know what is the difference between Genuine Porsche and OEM German?
2000 Boxster S
Old 05-26-2015, 10:41 AM   #3
if you do a search on replacement tanks (on this forum alone), you'll quickly understand why, although NOT cheapest option, you'll want to just bite bullet and go w/ genuine Porsche replacement tank.........
Good luck
"Cool Prius!"
- Nobody
Old 05-26-2015, 05:56 PM   #4
1998 Boxster
I just returned a reservoir that I had purchased NEW, for only $60 on EBay. I had decided that as difficult as I've heard the installation is, it just isn't worth rolling the dice on a cheap, Chinese part. Even though the part has a one year warranty; who wants to replace that defective, junk part with yet another cheap, Chinese, junk part that would have an equal likelyhood of failing?
rah rah 986 is offline   Reply With Quote
Old 05-27-2015, 08:01 AM   #5
2 fast 4 U
Ok but is there a difference between Genuine Porsche and OEM tank? Vertex auto has the OEM tank and I am wondering if this is a good product.
2000 Boxster S
Old 05-27-2015, 04:35 PM   #6
Hummer-addict's Avatar
I thought OEM is Genuine Porsche,GM,BMW,etc...
Hummer-addict is offline   Reply With Quote
Old 05-28-2015, 02:50 AM   #7
DrCactus's Avatar
Few years back my OEM one cracked and needed to be replaced. I ended up ordering a chinese one online for about $200 and the quality was excellant. The guy said they make these units for all around the world but he sells some privately to make a few bucks for his family. So far I have not had a problem and the installer did not run into any issues at all putting it in. The dealer wanted more than twice the price for the same part...
DrCactus
Old 05-29-2015, 03:49 AM   #8
1998 Boxster
In Pelican's catalog, there is a listing for a PORSCHE, and a listing for a GENUINE OEM PORSCHE. Which would be considered original equipment? And why would Porsche put their name on what appears to be two separate versions of the same thing? Or, are they the same thing?
Last edited by rah rah 986; 05-29-2015 at 03:51 AM. Reason: Missing content in first post
Old 05-29-2015, 04:36 AM   #9
Like most manufacturers, Porsche uses more than one source for everything in the car. So there are "genuine Porsche" what the dealer would sell you, and "OEM" which could be a secondary supplier, or some third party claiming their part meets the OEM specs, which is not always the case.
Old 05-29-2015, 04:44 AM   #10
1998 Boxster
I am guessing that only products that have been authorized to do so can wear the Porsche logo as does the OEM GENUINE PORSCHE reservoir listed in this catalog. By having the Porsche insignia, I am led to believe that the product meets Porsche high quality standards.
Old 05-29-2015, 05:26 AM   #11
Only if the vendor, and their sources, are to be trusted.
Old 05-29-2015, 06:56 AM   #12
To respond to your original question, I installed a tank (OEM) I sourced from Vertex about 2 months ago. I could not see any differences between the new one and the old one, other than the stains and cracks in the old one. Fit was fine with the exception of the new coolant level sensor. Seems there has been a change in the design requiring modification of the electrical connector. I reused the old one. All appears to be working well.
sandia is offline   Reply With Quote
