Old 05-21-2015, 05:52 PM   #1
Cleaning Interrior
I have a 2003 graphite grey interior, the roll bar pads are turning yellow, any suggestions on how and what to to use to clean,
03 986, Seal Grey, Graphite Grey, Black Top, Litronic, Cruise, OBC, Bose, 17"S-Color Crest, Alarm, PSM
BXTRBRU is offline   Reply With Quote
Old 05-21-2015, 06:56 PM   #2
Is anyone spraying suntan lotion around the car? Yellowing cushions have been a problem on boat cushions that come into contact with suntan lotion. I would try the Leatherworld Tech cleaner and then dye them if the cleaner did not work.
Old 05-22-2015, 06:57 AM   #3
Ckrikos's Avatar
Try a solution of 20% meguiars apc and 80% distilled water. Do not spray the intended area rather on a toothbrush and work it into the leather.
Start off with 10% apc and go to 20 if you need to. Its strong stuff and needs to be diluted or you will damage the interior.
This should clean the leather to like new, but don't do it often. Finally finish up with a leather conditioner.
LB/GG/MB 02 2.7 sold
MB/GG 02 996TT
Old 05-22-2015, 07:54 AM   #4
Perfectlap's Avatar
There's a famous German product line called Klasse. They have a product specifically for the interior previously known as VLRP (vinyl, leather, rubber,plastic) now called Klasse Cleaner Protectant. I would also give this a shot, another German product, called 1Z Leather while your in there cleaning stuff. It leaves the seats looking new, amazing how many layers of dyes from your jeans, pollution, etc. get stuck on a roadster interior.
KLASSE VINYL, LEATHER, RUBBER & PLASTIC-CLEANER/PROTECTANT
1Z Einszett Leather Care
Old 05-22-2015, 08:50 AM   #5
Go to the thread below. This guy had the same problem. I suggested a 'magic erasure' sold everywhere, and it worked!
http://986forum.com/forums/general-discussions/50310-nasty-leather.html
good luckl!
Old 05-22-2015, 09:12 AM   #6
Perfectlap's Avatar
^ I totally forgot about that thread, the funny thing is that since you posted that I now use the magic eraser to get the yellowing and streaks off the white parts of Nike's (Air Max 90). Works like a charm. Actually it works on all colors.
http://niketalk.com/image/id/409540
Old 05-22-2015, 10:05 AM   #7
Giller's Avatar
Be cautious where you use the 'magic' eraser. I had some scuffs on my dash that the eraser actually made worse (fortunately, I did it in a obscure location to test). Test in hidden location first. It will work in some areas, but others are more sensitive.
I think the rolls bars are more hearty and should be fine.
For the dash - ended up using Mequires Dash and Trim restorer, which worked okay.
Old 05-22-2015, 05:03 PM   #8
cleaning interrior
Thanks for the great tips, going to try them this weekend, I knew I could count on you guys to help
Old 05-23-2015, 11:51 AM   #9
Absolutely second the statement above. The magic eraser is actually abrasive.
Old 05-23-2015, 05:23 PM   #10
cleaning imterrior
I used Mothers Leather Tech and followed with the Conditioning Cream., great results. Ended up doing the whole inside.
Old 06-24-2016, 04:52 PM   #11
Administrator
We're bumping this old thread because some of you here said you like to use Einszett. That brand has now been reborn as Nextzett, retaining their same products and lead chemist.
This week only, the entire Nextzett line of car care products is 10% off! This includes Perls Shampoo, Blitz Cleaner, Cockpit Premium, ColourTec Wheel Cleaner and the ultimate in rubber protection, Gummi Pflege! There are plenty of other products too, all designed to restore any surface on your vehicle to its original luster.
For 10% off, enter promo code NEXT10 at Step #4 during checkout where it says, "Have a Promo Code? Apply it now."
Shop Nextzett now or browse the rest of our car care products section!
Matt at Pelican Parts is offline   Reply With Quote
