Old 05-22-2015, 04:57 PM   #41
I am my own mechanic....
Timco's Avatar
I think it is immobiliser - it will kill spark but still let you crank. so, security system is still on although doors are unlocked. try locking/unlocking doors w/ key and with fob. still got rf pill in fob?
I was sure hopeful, but nope. Not this. Car locks / unlocks fine.
Cranks great. Never even a puff or ignition of any kind. I'll look deeply into all grounds this evening to pass time I guess.
Damn. Car is on the ground, ready to try new clutch & all I did, and no fire up.
'08 VW Touareg T-3 wife's car
Old 05-22-2015, 05:45 PM   #42
never mind...
Old 05-22-2015, 07:01 PM   #43
78F350's Avatar
Did you mess with the area around the ignition key? If the transponder coil is unplugged it won't start even though the rest of the immobilizer/central locking unit is good.
Old 05-22-2015, 07:27 PM   #44
Chuck W.'s Avatar
Originally Posted by Heiko View Post
Check to make sure your CPS (Crank Position sensor) is plugged in properly and make sure its not defective...
I have been following this. Heiko's idea of the CPS may be worth looking at again. Can't hurt.
1995 Porsche C4 Cab
Old 05-22-2015, 07:32 PM   #45
Timco's Avatar
Never touched the switch. Not saying it isn't that, but never worked up there.
Old 05-22-2015, 07:35 PM   #46
Timco's Avatar
Someone posted how to test that and it ohmed out just like they said it would. Still replace?
Old 05-23-2015, 01:19 AM   #47
Steve Tinker's Avatar
Then it has to be the new flywheel that's at fault - you have checked everything else that you have touched, moved or replaced....
2001 MV Agusta F4.
Old 05-23-2015, 04:49 AM   #48
Timco's Avatar
Ugh. Straight from Pelican, perfectly identical. As I mentioned, I removed the CPS, and used a color inspection camera and watched the teeth rotate right past the camera face. Seemed perfect.
Really does seem like no spark. None at all. Beyond pissed about it at this point.
Would a Durametric say CPS failure or failure to see crank position?
Old 05-23-2015, 05:01 AM   #49
Timco's Avatar
Old 05-23-2015, 06:21 AM   #50
Timco's Avatar
Old 05-23-2015, 06:25 AM   #51
Beginner
Jamesp's Avatar
Timco,
Did you do the caveman spark test to 100% prove no spark? At this point you need data. The flywheel looks great. It is suspect because it is new, but I would not be taking it out without a whole lot more trouble shooting.
2003 S manual
Old 05-23-2015, 06:32 AM   #52
Beginner
Jamesp's Avatar
I've only run my Durametric a handful of times (around 10) so I'm a newbie. It works by reading the computer inputs when the engine is running. I don't think it is much help with the engine off.
2003 S manual
Old 05-23-2015, 06:37 AM   #53
Timco's Avatar
Old 05-23-2015, 06:43 AM   #54
Timco's Avatar
Originally Posted by Jamesp View Post
Timco,
Having a buddy come over to crank it so I don't have to rig the cave man test for solo experimentation.
As to the flywheel, it's like Miller Light.
Fellas, it just doesn't get any better than this.......
Old 05-23-2015, 08:59 AM   #55
Timco's Avatar
Fusible power distribution links are fine. Tried setting throttle after power up.
Have to buy a larger pressure gauge to fit the fuel rail shader. Doing that next.
Old 05-23-2015, 09:08 AM   #56
Timco's Avatar
Sorry to bump like this, but my AC gauges fit that fuel pressure shrader. With key on, zero psi took gauge off, pushed stem in, no gas.
secondary air pump not coming in either.
New suggestions to T/S?
Thanks a ton.
Old 05-23-2015, 09:40 AM   #57
Thanks a ton.
Search for the procedure to jump the fuel pump relay and see if that gets you pressure.
Old 05-23-2015, 10:03 AM   #58
Timco's Avatar
Bentley covers this.
No change with terminals jumped. No sound, no pressure.
I actually do hear SAI come on, it's just for 5-10 seconds.
Old 05-23-2015, 12:45 PM   #59
Beginner
Jamesp's Avatar
So what are the odds the fuel pump takes a powder after a 4 month rest? I had dire predictions for my fuel pump after my box sat for nearly 2 years without running, thankfully wrong. There has to be a way to provide 12V directly to the fuel pump to make sure it is working, AFTER the cave man test shows spark. This goes against the initial post where gas was evident by smelling it, but at this point it's a game of elimination.
2003 S manual
Old 05-23-2015, 12:47 PM   #60
Beginner
Jamesp's Avatar
And the SAI doesn't do squat, except set a CEL, and cost a boatload of cash.
2003 S manual
