Old 05-18-2015, 04:16 PM   #1
Headlight Lens - possible to clean or replace?
My headlights have a few brown spots, assumed to be burn spots from the halogen bulbs. Not exactly sure what bulbs are in there now, if they are at the suggested wattage or above (may have previously had headlight bulbs that ran too hot from previous owner).
I was going to remove the headlight bulbs and then try and get something (not exactly sure what) in there to see if I could clean the brown spots off.
Not sure if this is possible or not, or is it may even be possible to replace the lens itself (which I assume would then require opening the headlight assembly which then leads towards replacing the current halogens with bi-xenon projectors or more likely paying someone more equipped to do that kind of work).
Here is a pic of the lens now:
soxfan1966 is offline   Reply With Quote
Old 05-18-2015, 04:38 PM   #2
I am my own mechanic....
Timco's Avatar
A certain somebody will be along shortly.
He takes the outer cover off and refurbishes them. Then, you can get Nine8Six's projectors.
'08 VW Touareg T-3 wife's car
Old 05-18-2015, 05:17 PM   #3
+1.
Read through this thread -
Porsche Headlight Retrofit [from CAD, prototyping to finish)
You'll have to wait for Pelican to have the projectors in stock, but they are awesome. A cheap alternative would be to post a wanted ad for the clear inner lenses that are burned on yours - they get pulled when putting in Fred's projectors. There should be some floating around for near free. I was going to hang on to mine for a situation just like this (they were in great shape), but I broke too many of the tabs prying them out.
CraigM is offline   Reply With Quote
Old 05-19-2015, 07:26 PM   #4
EJ-Fresno's Avatar
Who is that certain somebody? I have the same yellowing issue...
2006 V6 Mustang
2008 ML 350
EJ-Fresno is offline   Reply With Quote
Old 05-20-2015, 06:12 AM   #5
BruceH's Avatar
Particlewave/Charles. Great guy and does wonders with headlights among other things
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
