Old 05-14-2015, 07:42 AM   #1
jpc763's Avatar
Alarm Question
I have a 2001 Boxster S that I recently replaced the head unit. I followed the instruction to make sure that the cable was attached to the harness. My install involved pulling the unit out many times. Apparently I was not successful in keeping it in contact. As a result, my car beeps once every time I lock it.
My question is... If I do nothing, is my car still secure when I lock it (except for the stereo)? I really don't want to pull the stereo out AGAIN!
Thanks, John
jpc763 is offline   Reply With Quote
Old 05-14-2015, 02:12 PM   #2
Finnegan's Avatar
I've been meaning to ask about the alarm too. My '04 base chirps once when I lock it, sometimes. Like, every 20th time. Is there a way to adjust that setting?
Old 05-14-2015, 02:17 PM   #3
98 Arctic silver 986
tommy583's Avatar
If it chirps than something isn't closed. The most likely thing is the cover on the center console. The stereo alarm wire either has to be grounded or not grounded, I can't remember which it is. Do a search, I'm sure it's on here somewhere. If the horn does chirp then the interior motion alarm is disabled I believe.
tommy583 is online now   Reply With Quote
Old 05-14-2015, 04:59 PM   #4
Mine mostly chirps on locking. If I unlock it right away and lock it again, sometimes it doesn't chirp the second time. No faults showing on Durametric. Maybe my car's computer is hooped.
Old 05-14-2015, 06:47 PM   #5
M31
M31's Avatar
I had the same problem with mine chirping after the head unit was replaced. The installer couldn't find the solution so I took my 2002 Boxster S to a local Porsche dealer who fixed it while I waited. This is a quote from the dealer invoice: "Inspect radio contact wires as per customer supplied instructions. Wires already connected to harness ground. Removed and ran independent ground. No change of operation. Noted that the radio contacts are suppose to be normally open circuits. Removed grounds and tapped connectors. System now operating normally"...this solved the chirping and it never did it again...hope this helps!
M31 is offline   Reply With Quote
Old 05-14-2015, 07:09 PM   #6
Pdwight's Avatar
Easy Peezy
Once you remove the original head unit look in the opening on the drivers side and you will see a little spring loaded contact with a spade lug wire on it. Remove the wore, tape it up or cut the spade off. This was to alarm in case the head unit was removed...problem solved
