Old 05-09-2015, 10:22 AM   #1
Front hood light switch
Every time I work in the front of the car and the hood is up, the compartment light automatically turns on. I wish Porsche designer placed a switch to turn off this light so you have a choice to save power from the battery. What I normally do is to pull out the light module and disconnect the wiring. And this is not good if you do it all the time you work in there. So I decided if I can replace that light module with a dome light that is typically used on all cars. So what I did is, I went to car junk yard and found a used dome light from a Hyundai car. I took and bought this dome light for $5 and painted it black. It was originally in silver. I cut out and glued this dome light and now, I can turn off and on the light whenever I needed it. Please see the attached pictures.:dance:
itoy is offline   Reply With Quote
Old 09-21-2022, 05:10 PM   #2
This is a great idea! Will be doing this myself… my battery died because of this light. I hanks so much for sharing your idea. 😊❤️
Arthsac is offline   Reply With Quote
Old 09-21-2022, 06:07 PM   #3
you could also just put a toggle switch in line with the 12v+ wire.
What work are you doing though in the front trunk when it's dark out?
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
