Old 05-02-2015, 04:25 PM   #1
ScottStu's Avatar
My first oil change on my Boxster
So with all the posts on the IMS issue and that fact that I just bought it two weeks ago I got everything together and changed the oil on the old girl.
I took the filter apart and took a magnet to it to check for metal flacks. No metal but I did find some black plastic in the filter...do I need to worry?
ScottStu is offline   Reply With Quote
Old 05-02-2015, 05:29 PM   #2
Pdwight's Avatar
I am by no means an expert, but this could be stringers from a gasket or "bumpers" for the timing chains....sorry for poor nomenclature
Old 05-02-2015, 06:56 PM   #3
ScottStu's Avatar
Its my first Porsche, is this bad?
Old 05-02-2015, 07:24 PM   #4
No worry. Hard plastic black or brown bits are chain tensioner material. Crème or brown colored rubbery bits are left over sealant. A small amount of either is normal.
If you see this, then you need to worry (a lot);
Old 05-03-2015, 02:59 AM   #5
ScottStu's Avatar
Thanks thstone. That even looks bad...
