Old 04-28-2015, 01:13 AM   #1
Tiptronic question
Is it true that the tiptronic shift on the 986 in many case happen to be not working/functioning?
The normal automatic gear shift is working just fine.
How much does it cost to fix it? Thank you.
sunnyguy99 is offline   Reply With Quote
Old 04-28-2015, 01:30 AM   #2
Need For Speed
KRAM36's Avatar
Never heard of it happening. What exactly is broken?
2003 Boxster S
Old 04-28-2015, 02:11 AM   #3
just modify my question. Sorry for the confusion.
Old 04-28-2015, 03:15 AM   #4
Giller's Avatar
sounds like you are having a problem with the manual mode on the tip? Might need to describe the problem in more detail. Either way, I've never had a prob and haven't heard of any problems with manual mode vs. regular automatic mode.
Old 04-28-2015, 06:30 AM   #5
Need For Speed
KRAM36's Avatar
When you push the gear shifter to the manual shift position, does the dash light show it's in manual mode?
2003 Boxster S
Old 04-28-2015, 07:11 AM   #6
The dash light show manual mode when push the gear shifter to the manual shift position.
Could it be something wrong with the mechanical part of the transmission. I am worried that the cost of fixing it would be expensive.
Old 04-28-2015, 08:30 AM   #7
Luv2Box's Avatar
It could be a problem of the Tip ECU not sensing it is in "M."
Luv2Box is offline   Reply With Quote
Old 04-28-2015, 08:32 AM   #8
Need For Speed
KRAM36's Avatar
Have you checked the fluid level? When was the last time you changed the filter and fluid?
Could be a solenoid valve.
A86.00 Tiptronic -99 A86.05 00- A86.20 Switch Unit Solenoid Valve Pressure Regulator 00-
2003 Boxster S
Tags
tiptronic
