04-20-2015, 05:27 PM
Top won't drop
Put the car to bed for the winter and all was well. Brought it out today and the top won't move. Release the latch and the windows go down but hit the button and nothing. Where should I start? 02 S model, if that matters.
Also, it was on a CTEK tender all winter.
04-20-2015, 05:35 PM
Porsche "Purist"
Check fuses and top relay.
1987 924S. 2002 996TT. PST-2
04-20-2015, 05:53 PM
How the bleep do you get the cover off the fuse box without breaking it??
Never mind, just forced it.
04-20-2015, 06:02 PM
Registered Boxster abuser
lol yeah mine stuck a little the other day. Stick your finger in the hole and pull...
04-20-2015, 06:19 PM
Fuse is good, how do I check the relay?
04-20-2015, 06:33 PM
Ok, found the problem. Hand brake switch. Now, where is that switch located?
04-20-2015, 06:39 PM
Have to pull the console to get to the switch
04-20-2015, 06:40 PM
Its a $5 part under the hand brake. Kind of need to pull the console to get to it, The easier solution is to bypass the handbrake by grounding a pin on the top relay. I've been running like this (also bypassed the speed control) for 5 years without a hitch.
04-20-2015, 06:41 PM
04-20-2015, 06:47 PM
Top bypass the hadbrake, pull the top control relay, bend pin 15 out of the socket and ground it to a nearby ground.
To drop the top while in motion, bend pin 18 out of the socket.
Reference Mike Focke's top section on his Boxster Page.
04-20-2015, 07:43 PM
Thanks everyone!
04-21-2015, 03:49 AM
I am my own mechanic....
Today's project! Please, when your membership is up, allow me to renew it as a small thanks.
'08 VW Touareg T-3 wife's car
04-21-2015, 07:02 AM
I had to change that switch, removing the console is pretty easy
04-21-2015, 07:31 AM
Luckyed
OR.......replace the module with a Comfort Top module.
2001 Base 2.7 - Arctic Silver - 5 speed - Comfort Top -
3-4 Stalk OBC Upgrade - Double DIN Head Unit
04-21-2015, 08:25 AM
That's what she said....
Lov'n my boxster!
2013 Lexus IS350awd
2007 Toyota FJ Cruiser
2004 Porsche Boxster S
