Old 04-20-2015, 06:27 PM   #1
CHRISP357's Avatar
Top won't drop
Put the car to bed for the winter and all was well. Brought it out today and the top won't move. Release the latch and the windows go down but hit the button and nothing. Where should I start? 02 S model, if that matters.
Also, it was on a CTEK tender all winter.
CHRISP357 is offline   Reply With Quote
Old 04-20-2015, 06:35 PM   #2
Porsche "Purist"
Paul's Avatar
Check fuses and top relay.
1987 924S. 2002 996TT. PST-2
Old 04-20-2015, 06:53 PM   #3
CHRISP357's Avatar
How the bleep do you get the cover off the fuse box without breaking it??
Never mind, just forced it.
Old 04-20-2015, 07:02 PM   #4
Registered Boxster abuser
healthservices's Avatar
lol yeah mine stuck a little the other day. Stick your finger in the hole and pull...
Old 04-20-2015, 07:19 PM   #5
CHRISP357's Avatar
Fuse is good, how do I check the relay?
Old 04-20-2015, 07:33 PM   #6
CHRISP357's Avatar
Ok, found the problem. Hand brake switch. Now, where is that switch located?
Old 04-20-2015, 07:39 PM   #7
Have to pull the console to get to the switch
Old 04-20-2015, 07:40 PM   #8
Its a $5 part under the hand brake. Kind of need to pull the console to get to it, The easier solution is to bypass the handbrake by grounding a pin on the top relay. I've been running like this (also bypassed the speed control) for 5 years without a hitch.
Old 04-20-2015, 07:41 PM   #9
Boxster Projects | Parking Brake Sensor Switch
gives you a couple ideas
Old 04-20-2015, 07:47 PM   #10
Top bypass the hadbrake, pull the top control relay, bend pin 15 out of the socket and ground it to a nearby ground.
To drop the top while in motion, bend pin 18 out of the socket.
Reference Mike Focke's top section on his Boxster Page.
Old 04-20-2015, 08:43 PM   #11
CHRISP357's Avatar
Thanks everyone!
Old 04-21-2015, 04:49 AM   #12
I am my own mechanic....
Timco's Avatar
Today's project! Please, when your membership is up, allow me to renew it as a small thanks.
'08 VW Touareg T-3 wife's car
Old 04-21-2015, 08:02 AM   #13
Fintro11's Avatar
I had to change that switch, removing the console is pretty easy
Old 04-21-2015, 08:31 AM   #14
Luckyed
Luckyed's Avatar
OR.......replace the module with a Comfort Top module.
2001 Base 2.7 - Arctic Silver - 5 speed - Comfort Top -
3-4 Stalk OBC Upgrade - Double DIN Head Unit
Luckyed is offline   Reply With Quote
Old 04-21-2015, 09:25 AM   #15
tnoice's Avatar
That's what she said....
Lov'n my boxster!
2013 Lexus IS350awd
2007 Toyota FJ Cruiser
2004 Porsche Boxster S
tnoice is offline   Reply With Quote
