Old 04-18-2015, 04:05 PM   #1
Pdwight's Avatar
Got a break wear light
But the pads are new 4 months ago, any way to tell which wheel it is short of taking each off and swapping out the sensor ?
Old 04-18-2015, 04:09 PM   #2
Need For Speed
KRAM36's Avatar
The wire gets cut by the rotor, has nothing to do with how new your pads are. Sounds like you need new rotors. You can buy rotors with new wires as a package deal.
2003 Boxster S
Old 04-18-2015, 04:19 PM   #3
Um I don't think you're correct there. The nub of the sensor gets worn through when the pads wear down enough to expose it. I mean, yes, the rotor does wear through the sensor, but only when the pad is sufficiently thin to allow this to happen. The sensor is there to monitor brake pad wear, not rotor wear. Your rotors could be paper thin and that alone will not cause the indicator light to go on.
In this case it sounds like it might be just a bad connection. Check the connectors to the sensors to see if one has worked loose or fallen off. Could also be a defective sensor, which you can determine by checking for continuity through the sensor with your multimeter. Also check and see if the section of wire between the sensors has been pinched or broken.
Checking for continuity (this one is good):
'99 black 986
Old 04-18-2015, 04:33 PM   #4
You should be able to do all this without any disassembly other than unplugging the sensor connector to do the continuity test.
'99 black 986
Old 04-18-2015, 04:35 PM   #5
Need For Speed
KRAM36's Avatar
Um I don't think you're correct there. The nub of the sensor gets worn through when the pads wear down enough to expose it. I mean, yes, the rotor does cut the sensor, but only when the pad is sufficiently thin to allow this to happen.
Thickness of the pads have nothing to do with it in this case. It's the rotors being so worn they cut through the wire.
2003 Boxster S
Old 04-18-2015, 04:37 PM   #6
Sorry, but you're wrong.
'99 black 986
Old 04-18-2015, 04:38 PM   #7
I am my own mechanic....
Timco's Avatar
Originally Posted by KRAM36 View Post
Thickness of the pads have nothing to do with it. It's the rotors being so worn they cut through the wire.
The sensor tip is inserted into the pad. When the pad wears enough the wire makes contact with the rotor once it's exposed through the worn pad. This is the only way they trip unless one is unplugged or damaged.
'08 VW Touareg T-3 wife's car
Old 04-18-2015, 04:39 PM   #8
Timco's Avatar
This...........
Old 04-18-2015, 04:42 PM   #9
Exactly, and it is a lack of continuity through one or more of these circuits that causes the wear indicator to light up.
'99 black 986
Old 04-18-2015, 04:51 PM   #10
Timco's Avatar
Or if the wire shorts to ground the second the jacket wears off. I had a pad light and it came on when the pads were wet and it shorted to ground through the rotor.
Old 04-18-2015, 05:05 PM   #11
Need For Speed
KRAM36's Avatar
Ok, lets see what he finds out. I'm putting my money on the rotors.
2003 Boxster S
Old 04-18-2015, 05:23 PM   #12
Registered Boxster abuser
healthservices's Avatar
Probably just routed one of the wear indicator wires incorrectly and it got nicked.
Old 04-18-2015, 05:24 PM   #13
steved0x's Avatar
If you have been doing heavy braking like at the track one may have melted. Probably one of the fronts.
Old 04-18-2015, 06:40 PM   #14
Timco's Avatar
It's just not possible, bro. The wire is even clipped into the pad retaining bracket so it cannot possibly touch the rotor. Only a micrometer can check the rotor thickness.
Please. I'm begging you. Think about it.
If not, make it $100??
Old 04-18-2015, 07:42 PM   #15
Need For Speed
KRAM36's Avatar
Well then these guys are giving out bad information.
Grinding, pulsating and a lack of stopping power are signs of a bad brake rotor. If your brake pads have worn deep into your rotor, the lip on the outer edge of the rotor can cut into your pad wear sensors, causing a brake pad warning to appear in the instrument cluster - even if your brake pads are new. Rotors should be checked every time you service your brakes.
2003 Porsche Boxster Roadster S H6 3.2L Braking Rotors - 99635140501KT - Front Brake Rotors - Pair 12.51" (318mm) - ES#2535370
2003 Boxster S
Old 04-18-2015, 07:48 PM   #16
If it's on the Internet it must be true.... lol
Old 04-18-2015, 07:51 PM   #17
Need For Speed
KRAM36's Avatar
It's on a very highly respected website and parts dealer.
2003 Boxster S
Old 04-18-2015, 07:59 PM   #18
It on a very highly respected website and parts dealer.
LMAO
Not to attack you but...
logically, look at where the sensors are mounted, they are on the brake pads and the wear portion of the pads no less. How is it possible that it can measure the thickness of the rotor?
Old 04-18-2015, 08:06 PM   #19
And I'd really be laughing my butt off though if we were wrong and you were right Kram.
Old 04-18-2015, 08:42 PM   #20
Need For Speed
KRAM36's Avatar
LMAO
Reread what I posted. It has nothing to do with reading the the thickness of the rotor, it has to do with the rotor being so worn out the edge of the rotor cuts the wire.
If I'm wrong, then I'm wrong, but this is what I have read from a very well respected Porsche parts seller. I didn't just pull it out of the air.
2003 Boxster S
