Old 04-13-2015, 03:25 PM   #1
jpc763's Avatar
Two Boxster Manual Transmission Questions - Random stuff
Questions for you all.
1) When parking, do you leave the car in gear or not?
2) When idling at a traffic light, In gear (with clutch in) or not?
jpc763 is offline   Reply With Quote
Old 04-13-2015, 03:34 PM   #2
still plays with cars...
BoxsterSteve's Avatar
When parking, I'll leave the car in gear and pull the handbrake too.
Always idle in neutral with the clutch up. Your clutch will thank you.
Six speed 2000 Boxster S
Old 04-13-2015, 06:38 PM   #3
Multi-Boxer Driver
Deserion's Avatar
In gear and parking brake on when parked. In neutral and clutch out when idle.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 04-13-2015, 09:34 PM   #4
You mean throw out bearing?
Although a worn throw out bearing is arguably cheaper and easier to replace than a main shaft bearing in the transmission....but that's probably not going to go bad.
IMO don't worry about clutch in/out when at a light. Short light, clutch in (also leaves you with a quick getaway if needed, long light in neutral). The throw out bearing would get replaced when you're doing the clutch anyways so it isn't like you'll burn it up first
mack73 is offline   Reply With Quote
Old 04-14-2015, 06:39 AM   #5
CoBeerToad's Avatar
I meant to ask about that when someone posted the PPI checklist a while back. What is wearing when you have the clutch depressed when at a light? Sometimes I leave it depressed and sometimes not and I can't think of what difference it makes.
CoBeerToad is offline   Reply With Quote
Old 04-14-2015, 09:25 AM   #6
BIGJake111's Avatar
When parked, I leave the car in gear, against the slope with parking brake.
At lights, I am usually still in gear unless it goes red on me coming up to it I'll take neutral.
Old 04-14-2015, 04:03 PM   #7
Beginner
Jamesp's Avatar
In neutral and parking brake on when parked unless on a hill, the parking brake and in gear.
At lights I'm in neutral and in fact just coast around a lot in neutral when decelerating. Keeping the clutch pedal pushed keeps the throw out bearing engaged and spinning under load. My thought is there's no reason to put the extra wear on the bearing.
2003 S manual
Old 04-14-2015, 09:24 PM   #8
Same for me.
Old 04-14-2015, 09:42 PM   #9
rdass623's Avatar
generally the throw out bearing wear is not the problem with keeping the car in gear when at a stop light. the main problem with foot on the clutch was wear on the thrust washers in older cars, primarily older brit four bangers which had poor oiling systems.
1977 Toyota Celica GT
rdass623 is offline   Reply With Quote
