Old 04-09-2015, 05:24 PM   #1
A.C> Compressor Causes Vibration
When the A.C. comperssor is on it causes substational vibration iin steering wheel. Found one post which mentioned radiator fans on the drivers side? Any thoughts?
nicecar is offline   Reply With Quote
Old 04-09-2015, 07:23 PM   #2
Registered Boxster abuser
healthservices's Avatar
Sounds easy enough if you think that is the issue, jump the wires at the fan relay with the engine off and see if that is the issue.
Old 04-10-2015, 12:08 PM   #3
thanks! any other causes ac related?
