Old 03-29-2015, 12:18 PM   #1
Blend Door Motor Linkages - Need Picture
OK - I need some help with a photo or diagram of the lever/armature that controls the blend door. I disassembled mine and can't figure out the correct way to put it all back together.
I replaced the missing foam in the blend door. I loosened the motor for the blend door above the passenger foot well. The linkages came loose and I cannot figure out how to reassemble them correctly. I can't find any picture of it in the Bentley or 101 Projects Book.
Old 03-29-2015, 02:38 PM   #2
Pdwight's Avatar
Tag, I want to follow this
Old 03-29-2015, 04:28 PM   #3
I may have figured out the correct routing to the linkages.
Old 03-30-2015, 04:59 PM   #4
After walking away for a couple of hours the correct path to route the linkages was made. The middle bar runs towards the transmission tunnel, linking the pink lever on the actuator motor lever on the blend door. The blend door linkage can go either of two way, but when the middle bar is in the proper position, the positioning will be obvious (to most everyone but me).
Old 03-30-2015, 09:21 PM   #5
Registered Boxster abuser
healthservices's Avatar
how about a picture?
Old 03-31-2015, 05:12 AM   #6
Hah! No fair, I asked for one first. I tried a few shots with my cell phone. All of the pieces under there are black, except for the pink lever on the actutor motor, making it hard to see the parts.
