Old 03-29-2015, 10:54 AM   #1
Duquette5's Avatar
Replacing the AOS
So today I decided to tackle the AOS. A couple of notes since I had to stop half way thru for work:
The top bolt is a bear to get at.
I need to go pick up the spring clamp pliers from Sears.
I need to order a new J Tube
Now... how the heck do you get the side hose off?! My big mitts don't fit in there too well!
Thanks!
Mike
Located in Central Mass.
'00 Boxster
Duquette5 is offline   Reply With Quote
Old 03-29-2015, 11:00 AM   #2
AOS replacement tips
Excerpt: Getting the plastic connector off the middle of the AOS (towards passenger side) was a real pain, as I couldn't really get a good grip on it when accessing from the top or underneath. After struggling with this for a while myself, I had an assistant, working from the top, put pressure on and wiggle the hose towards the passenger side while I worked to compress the release tabs from under the car. Be very careful that you don't break this connector!! Replacing this hose is a serious pain.
clickman is online now   Reply With Quote
Old 03-29-2015, 11:12 AM   #3
Duquette5's Avatar
Thanks for the quick reply Norm. I suppose it would help if I had an assistant with me today and if I didn't have BahJumbo Gorilla arms
Will wrap up removal/replacement tomorrow and do plugs, oil and filter while I'm at it.
'00 Boxster
